Dust Collection
RE: Heating System & Dust Collection
10/21/20
Ken
We currently have a second floor woodshop approximately 10,000 sq. ft., and use portable dust collection bag attachments for all our professional woodworking machines.
We are located in the Northeast and have to install a heating system in the area. What would be the ideal system and where would we place the heating units? Our concern is the flammability of the heating in a wood shop.
The other question we have is what is the best way to build a sanding room approximately 10 ft. X 16 ft. ? What kind of central dust collection system would be recommended for the room?
10/24/20       #2: RE: Heating System & Dust Colle ...
RE: Heating....
Whats your issue? Are you not going to be using sealed combustion? Flammability would only be an issue with open flame combustion. Sealed combustion you can have your heat source in virtually any proximity to your dust. Air filtration and the like to save you headaches and keep dust out of your heat exchanger is simply basic.
Second quesiton.......
11/14/20       #3: RE: Heating System & Dust Colle ...
BH Davis  Member
Hot air heating systems with the furnace in a separate furnace room is a good system. However along with the primary furnace filter the addition of pre-filter intake boxes at the cold air returns is a must. Cleaning the filters on a regular schedule..........as often as daily if in dusty conditions........is necessary.
Sanding rooms are nice but downdraft sanding tables in sanding rooms is even better.
11/17/20       #4: RE: Heating System & Dust Colle ...
Vincenzo Celeste
At Coima USA we have dusting booth and very industrial downdraft tables
www.coimausa.com
Let me know if I can help.
    • American Fabric Filter Co.
    • GreCon
    • RT Machine Co.
    • Air Handling Systems
    • Sandman Products
