Subject: Re: Polishing rubbing machines needed
3/31/15
Ed Kerry Member
Does anyone know where I can buy good quality double pad polishing/ rubbing machines as it looks like they have stopped making??
I am ok with used, or reconditioned units as long as they are in decent working order...
Thanks..
3/31/15       #2: Polishing rubbing machines needed ...
Paul Snyder  Member
You should still be able to find the National Detroit 300/A for around $750. Stuhr and Chicago Pneumatic discontinued their dual pad inline sanders.
4/1/15       #3: Polishing rubbing machines needed ...
Robert Member
Sold off a few of the National inlines when I retired. We used them for wet sanding conference tables and larger flat surfaces. Found them to be not very good at polishing or buffing but on occasion would put on a White Scotch Brite pad and wet sand a finished surface with wool wax.
Check out eBay ..they pop up every now and then.
