Subject: Re: Tacky lacquer
Tacky lacquer
5/22/17
Mike G Member
Website: http://www.mgregorio.com
Hi. Hoping someone can help me out. I refinish furniture, and occasionally I have issues with the lacquer staying tacky and glossy in some areas. It would take about a day for the tacky areas to fully dry. Anyone know what can be causing this problem, and how to avoid it?
Thanks.
5/22/17       #2: Tacky lacquer ...
Robert Member
Thats usually a " wax " that's left over from the stripping material. Most, if not all removers contain some wax. The wax retards the evaporation of the remover.
After you have stripped the piece, wash/rinse it better with your solvent.
For the immediate issue, GENTLY hit that wet area with a cotton rag dipped in some Naptha.
5/22/17       #3: Tacky lacquer ...
Not a lot of background information to the prep. Chemical stripper? Post wash? Any sealer? How much sanding? Solvent or water based lacquer? More information will certainly help us help you.
5/23/17       #4: Tacky lacquer ...
Paul Snyder  Member
Website: finishing.tips
Just to add to Robert's reply, if you have tacky spots you can swipe them VERY gently with a soft cloth wetted with naphtha to remove the wax. The finish will dry pretty quickly once the wax is gone.
