Subject: Re: Fisheye!
Fisheye!
11/20/17
jacob
I have the dreaded fisheye! I bleached some cherry [ using the 2 part stuff] and then washed it down with a diluted mixture of vinegar and water [ saw it on a website] then stained etc and have fisheye!
I have bleached many times with no side effects [ but washed with thinners] and have sprayed thousands of panels in my time...i have checked compressor and everything.
my question is can the vinegar have caused this?? does anyone know?
thankyou!
11/20/17       #2: Fisheye! ...
Shane
your issue is not from the vinegar/water.. it's contamination from somewhere... sometimes it just shows up and after you muscle through to fix it ... somehow it disappears for a while.... it could be anything... oil in lines.... something on your hands... you name it.... we narrowed some contamination once in one of my booths... changed to different batch of material.... then changed kremlin pumps to another pump/gun setup.... and the fisheys kept coming in that booth.. they seemed to dwindle out but came back every day like a virus.... upon further investigation I asked my guy what he has been doing different and he had changed deodorants.... bam... we had him bring it in... and I wiped a bit on my fingers and put it on a sample board... shot some clear and it crawled like crazy... the silicone in the deodorant was spreading down his body and contaminating his work area..... I had him taking a bird bath at the shop scrubbing himself down and never use that deodorant again... unfortunetly now I forget which one it was!!!!
11/20/17       #3: Fisheye! ...
Jim Clark
Spray something clean, like a sheet of glass, If it doesn't fish eye, then air source is probably ok.
11/20/17       #4: Fisheye! ...
I met with some finishers at a custom woodworking conference years ago. Their employer forbid them to use any deodorant, or skin cream. Be careful if you use fish eye eliminator. Many refuse to use a gun that has been used for that on other fresh work.
11/21/17       #5: Fisheye! ...
Bob Niemeyer  Member
FIsheyes? Just another day in the refinishing world we live in. Don't freak out about it. Just work through it. Use the proper additives as needed and taper off thier use as you work to the end of the project. Never use more than directed as this can cause more issues and make certain stain colors look cloudy or reds a little purple.
FYI, not all silicones are cross contaminative as most think. After a wash out with thinner issues will be gone.
What most people dont know as most topcoats out there have silicone in the formulation, so they are spraying it and don't even know it.
Silicones are used everywhere, as plastic injection mold release to the shampoo we use to wash our hair.
