Subject: Re: Recomendation on Sander + Wirebrush Machine (mid-size prodduction floor
Recomendation on Sander + Wirebrush Machine (mid-size prodduction flooring)
2/17/18
Dustin Member
Website: http://rhodeshardwoodflooring.com
I'm wanting to start finishing wood flooring and paneling and have found the flat line finishing set up I want. However, I'm needing to also figure out sanding and a wire brush set up. Hoping someone might be able to offer a recommendation on these for small-medium size production (maybe 1,000sf per day).
Would prefer something with an infeed and out feed that allows me to keep feeding boards through it. One wire brush I've been considering is Stanza's.
Any advise would be appreciated. Thanks!
2/17/18       #3: Recomendation on Sander + Wirebrush ...
Bob Niemeyer  Member
Dustin, It looks like a nice machine. Can you go to a dealer and run boards and see what it can do? I have seen at some places guys need to run boards through the machine twice(opposite ends first) this will give a nicer look. But some of that may be due to how their machine is set up.
With machines it is all about service when it breaks, do they have parts here in the USA?
Down time cost $$$
2/23/18       #4: Recomendation on Sander + Wirebrush ...
Matt Krig Member
Website: https://northlandwoodworksinc.com/
Dustin ,Check out SuperMaxx for the wire brushing.
You are welcome to come by our cabinet shop in Blaine and check out our 53"-3 head sander set up any time.
https://www.supermaxtools.com/products/wood/superbrush-double-brush-sande
rs/
3/25/18       #5: Recomendation on Sander + Wirebrush ...
Adam West  Member
What kind of stock removal do you need and what grit belt do you want to end with.
7/23/18       #6: Recomendation on Sander + Wirebrush ...
Mike DeSarno
Website: http://www.stanzamachinery.com
We offer wire brush machines, located in Charlotte, NC. Feel free to call or email to go over. There are several models and price point machines.
mike@stanzamachinery.com
704-599-0623
View higher quality, full size image (1200 X 833)
