Subject: Re: Adhesion issues
Adhesion issues
10/23/18
Jason
I’m having a problem that I am hoping someone can help me with. I am using flat sawn red oak that I am bleaching twice then washing with vinegar to neutralize. After drying for several days I am spray staining with Gemini microlift. I let the stain dry overnight then sealing with Sherwin Williams kemvar conversion varnish. Letting it sit overnight then scuffing and top coating. When I put the second coat on within a couple minutes the finish wrinkles. I have never seen such bad finish failure. Now I have already done a good portion of this project without any problem, but when I started to do the doors and drawer front I started having the problems. The only thing that I have done different in the process is I had to change the bleach. What I used on the first batch was a 3-1 solution. I ran out of that bleach, so I contacted my manufacturer. The manufacturer said that bleach was not available anymore, so I had to get bleach that was now 1-1 solution. I still followed the neutralizing protocol and let dry for several days. This is where the problem seems to be coming from, but I am wondering if anyone has had this problem or maybe can steer me in the right direction for a solution to this problem and hopefully a fix. thanks
10/23/18       #2: Adhesion issues ...
I'd assume the surface is too acidic. Try a sample using a wash with distilled water, then a baking soda/distilled water mix.
10/23/18       #3: Adhesion issues ...
Try that wash without the vinegar.
10/24/18       #4: Adhesion issues ...
Shane
Tell us exactly how your mixing the kemvar.... product# catalyst# reducer's, retarder's etc etc....amounts/ratios ect. ect.
I'm very familiar with Kemvar C.V.
In my experience with kemvar wrinkling it's because the first coat was sanded too aggressive... any burn through our thin spots are susceptible to being lifted by the next coat..... this can also happen if you are reducing with a solvent that's not recommended..... Let me know how your mixing because your process sounds just fine. We generally seal with T67F7 catalyzed with v66v26 at 2% instead of self seal but obviously you can just use itself as a sealer as well...
10/24/18       #5: Adhesion issues ...
Jim Clark
If you're thinning with lacquer thinner then
that's probably the culprit.
Most lacquer thinners these days are
reconstituted junk, and very "hot"
I started using auto grade urethane reducer
several years ago and it works much better.
You may try that.
You can find it at any auto paint store.
10/24/18       #6: Adhesion issues ...
Jason
Using kemvar dull rubbed effect v84 f 83 catalyst v66 v 21. Using as self sealer. Scuffing with fine scuff pad then top coat. I am not reducing either coat.
10/24/18       #7: Adhesion issues ...
Tyler Member
this time of year with the cold the finish can act a little thicker. If you're not reducing it at all and applying too much finish, you could be having an issue where the bottom coat isnt properly drying. Try 5-10% reducer, it may help
10/24/18       #8: Adhesion issues ...
Shane
Im running a bleach job right now on red grandis solid with that exact same topcoat.... we are bleaching the hardwood up to 6-7 times to get all the color out...wipe down with straight vinegar and staining/sealing the next day... Only difference is that I'm sealing with t67f7 and the topcoat im reducing 20% with butyl acetate to keep the film thickness low for open pore look... No issues with PH or wrinkling..
11/9/18       #9: Adhesion issues ...
John L
I’m guessing that on your 3:1 discontinued bleach product it was 3 parts hydrogen peroxide to 1 part sodium hydroxide. With the replacement product at 1:1, you’re likely ending up with more residual lye salts on the wood with a higher ratio of lye to hydrogen peroxide. When you neutralize with vinegar, the vinegar reacts with the residual lye salts creating sodium acetate, yet another salt, which is a desiccant, being both alcohol and water soluble. You likely have more of this stubborn salt on and in the wood and you need to remove it by washing it with hot distilled water and a microfiber towel. I’m guessing that the sodium acetate is combining with the butanol and propanol components in the Kemvar, actually acting like a drier, resulting in wrinkling. The stuff will migrate to the surface of your first coat. The salt wreaks havoc with waterborne finishes and shellac as well.
Was the discontinued bleach IFP brand?
