Subject: Re: Practical life of organic compound carbon filters
4/10/20
Mark  Member
Most of our finishing jobs go to a dedicated finishing shop, but like it or not I am slowing becoming "the guy" for small lacquer jobs at work. We also have to buy all of our own PPE, so when I spray I use a 3M 3000 series respirator with organic compound carbon filters. Because of the virus, I can't get filters at the local home depot like I normally do. How long do you guys in practice use these filters? Also, if you are not in a full hood, how important is it to protect your eyes? Spraying inside boxes, is when I am really aware that I should be thinking more about how this could effect my eyes. I am spraying in a huge wear-house, with a moderate fan in the door. I would love to hear any PPE pro tips you guys have. I only have so many brain cells, and I need to keep all that are left.
4/10/20       #2: Practical life of organic compound ...
mauricio poli
Maybe you can search a spray gun with a different tip to apply inside de boxes , that will create less over spray
4/10/20       #3: Practical life of organic compound ...
Bart
Get a full face mask. And get tear away lens shields. The bounce back will ruin your eyes. Advanz makes a goggle with 30 frames of rolling lens which is good option with a basic face mask. Technically the charcoal deteriorates pretty quick if left out. Like 7 days.(I built surfboards back in the 70/80s early 90's and lived in a mask) When not in use put it in a tupperware container.
my2cts
4/11/20       #4: Practical life of organic compound ...
Daniel Berlin Member
Totally agree on full face mask with lens shields.
Beyond that,
1. Get the cartridges that have the service life indicator (60921i) Then you don't have to care, it'll tell you how long it lasts.
2. Get resealable mylar bags and put the filters in them. They will last a lot longer.
4/11/20       #5: Practical life of organic compound ...
nicko
can you leave the backs off and spray them separate and then install them after everything drys.
nicko
4/11/20       #6: Practical life of organic compound ...
Chris
Why do you have to buy your own equipment.Should be a company expense.
Rather than going to Home Depot use a safety supply company.they will have better products and be more knowledgeable.
I use a full face supplied air system.
Try northern supply.
4/11/20       #7: Practical life of organic compound ...
Nick
Like Muaricio said, changing the tools you're using could dramatically lessen the amount of overspray you're exposed to..if you're not using a AAA setup, get one, it's amazing how little overspray they produce especially when spraying inside boxes.
Another option is to change the product your using. Going from solvent lacquer to a waterborne product could cut the amount of VOCs your exposed to by up to 90% (not to mention the personal safety benefits of going from a flammable product to a nonflammable one [a change that will save insurance $ too]).
4/11/20       #8: Practical life of organic compound ...
I guess the company you work for has never had a visit from OSHA, the local fire marshall, or insurance inspector? Hard to count all the issues in those pictures.
4/11/20       #9: Practical life of organic compound ...
I've always been told 8 hours of use and they are done.
4/11/20       #10: Practical life of organic compound ...
Daniel Shafner Member
Switch to the 3M 6000 series. It's so much more comfortable. Get the larger size because it's a tight fit as a mask sits on the bridge of your nose. If you're sporting a beard, either shave it off or you will need a fresh air supply respirator. I think federal guidelines are such that your employer is required to provide you with the proper PPE, but it's their choice what brands & models.
    • 2Sand
