Subject: Re: Durable sprayed white finish
11/30/20
Andy H
I have a child’s bed in pine/mdf bed that I need to finish in white. There’s a lot of surface area, and I don’t want to brush it. I use CAB acrylic lacquer for all my clear finishes,so I was trying to go that route. Sherwin Williams didn’t have what I wanted CAB acrylic white/vinyl primer) and weren’t very helpful in getting it or suggesting an alternative. I just need a durable white finish I can spray with my hvlp.
12/1/20       #2: Durable sprayed white finish ...
rich c
They don't want to help your cabinet shop get material? You went to an Industrial Sherwin Williams store?
12/1/20       #3: Durable sprayed white finish ...
Andy H
It’s a regular retail store. I’ve had an account there for 20 years.
Since COVID, they have been short staffed and inexperienced. I went in with the P-sheets for what I wanted, and the lady asked, “Where did you get this?” She then just grabbed two other products off the shelf. She claimed they were the right substitutes, but I said I needed to research it. It was a nitrocellulose sealer and “blending” white lacquer.
12/1/20       #4: Durable sprayed white finish ...
Shane Welch
call a product finishes division and have them ship the products you need to a retail store! your on the right track with a cab topcoat so it doesn't yellow out
12/1/20       #5: Durable sprayed white finish ...
Jim Clark Member
Their conversion varnish is a far superior
finish to lacquer, and it sprays easier.
SW also can make it any color you want.
Try it, like me, you'll never go back to
the outdated lacquer.
12/1/20       #6: Durable sprayed white finish ...
Andy H
I used water white conversion varnish on some stair treads in my home 10 years ago. It’s held up great. The only downside is having to add a catalyst.
I’ve been using the CAB acrylic longer with no complaints.
The conversion varnish sounds like the answer. I didn’t realize it was tintable. Thanks. I will study up on that.
12/2/20       #7: Durable sprayed white finish ...
Andy H
Jim,
Which conversion varnish do you use for tinting? The “water white” or the “hb pigmented”? Or something else?
I recall seeing the water white on the shelf.
12/2/20       #8: Durable sprayed white finish ...
Jim Clark Member
The can says "Kemvar Plus"
That's all I know.
I order from a SW store in Cincinnati Ohio,
I get the customer to pick the color from
any SW store here and give me the chip number and I give that to the supplier.
They'll mix any color.
The stuff is real thick.
12/14/20       #9: Durable sprayed white finish ...
Andy H
I ended up using the white conversion varnish. I had to travel 45 miles to an industrial coatings SW to get it.
I really love being able to use it as a primer/sealer as well. It sands nicely and doesn’t load up sandpaper. It has a real durable feel to it once it cures.
    • 2Sand
