Subject: Re: Sap
Sap
1/10/22
Gary
I just finished doing a pine project. and now 2 weeks later sap is coming through to the surface and laying on top of the finish. I use SW Sayerlack as my finish, I have tried a few different cleaners that removed the sap but buffed a shine into the topcoat wiping it up. Is there anything out there that would remove the sap with out changing the sheen?
View higher quality, full size image (642 X 1389)
1/10/22       #2: Sap ...
Mastercabman
You can try Naphtha
It shouldn't mess with the finish
As always try a small area first
1/10/22       #3: Sap ...
If the sap was not set in that wood with heat in a kiln, you're going to have to remove it from the pocket and try to get a permanent filler over it. Removal with a solvent will not keep the sap from seeping out when the home gets warm in the future.
    • 2Sand
