3M accuspray HGP leaking needle?
6/6/18
Shane
Any of you guys ever use the 3m accuspray one system or the HGP with pressure cup? I have had the non pressure one for about a year and have used it many times with good results... bought it on a whim for some automotive paint we had to do for some small production items.... Neat system and the cleanup factor is nice. My problem lies with the HGP version with pressure cup... bought two new guns and cup setups to help with some latex spraying we are running a big production on for a casino interior... some of the parts have details that the airless just gets too much paint.
Any who when spraying both guns are leaking paint from the needle where normally a packing seal would be... making a mess of my fingers when trying to paint.... any ideas? Tried different disposable heads from other batches.. all the same result.. Are they just junk or what?
6/6/20       #4: 3M accuspray HGP leaking needle? ...
hal norman
I too having issues but not sure. question, once tip is attached and air hose connected to gun, is air supposed to start to flow? it seems as the nozzle pushes trigger back a small amount so as soon as you go to adjust the pressure regulator there is air flow. is this normal?
    • Supergrit Abrasives
