Current good quality waterborne finishes
11/7/19
Mark  Member
After a 13 year hiatus from any steady cabinet work, I'm getting back into the fray with my own shop full time come spring
In the past I've finished with pre cat lacquers, CV, alkyd paints etc, but I don't have the money to set up an approved booth for those materials and truthfully don't wish to deal with the solvents, storage etc.
What are some good waterbased finishes these days?
11/7/19       #2: Current good quality waterborne fin ...
Daniel Berlin
For WB CV, either sherwin williams stuff (IE kem aqua plus or sayerlack hydro*) or Axalata stuff (Zenith)
For WB polyurethane, Milesi/ICA/ILVA, whichever you can get easiest.
If you can get >1, try them. There are quality differences between them, but they are all "good enough" in durability/etc, so your ability to use them and the support you get is what you should decide on.
Since I now own a 2 year old no-overhang kitchen that was destroyed by the use of crappy pre-cat lacquer, i'm just going to controversially/biasedly suggest that it no longer has a place in this day and age ;)
11/8/19       #3: Current good quality waterborne fin ...
david zaret Member
i've been using waterborne for a long time now, and now i've settled on sayerlack. spays very well with a good AAA, cleanup is easy, dries hard (especially with the catalyzer) and is sandable, and looks just great. that's half of it. the other half is that i can get it locally. not having to rely on shipping finish is wonderful.
11/8/19       #4: Current good quality waterborne fin ...
Just because it's water based, doesn't mean it's healthy for you. You still need to ventilate and keep dust from the shop settling on the fresh finish. Also your fire marshal and insurance agent will determine if you need a spray booth or not. Opting out could very easily not be an option.
11/8/19       #5: Current good quality waterborne fin ...
Denny J
The Italian companies are the top of the market right now.
ICA, ILVM, Renner etc all have advanced product lines suited to many applications.
11/8/19       #6: Current good quality waterborne fin ...
I dont know for sure across the nation but I dont know any fire marshall or insurance company that would force any sort of explosion/booth issue with waterborne clause. Heck, even the EPA doesnt care on an open face solvent booth if you blow out with filters an a wall fan and down into a water trough.
If your insurance policy is noted with regards to waterborne and you blow your shop off the property sneaking in some solvent work you wont be covered. Same with fire marshal. They walk in for a random unannounced inspection the day you sneak some solvent in the booth and your poof (maybe in more ways than one). I could see your insurance giving you some booth grief if they are also carrying your comp for employees but thats a different ball of wax.
Wouldnt surprise me though with some of the stuff Ive heard around the country but its never been an issue here with either party mentioned.
11/9/19       #7: Current good quality waterborne fin ...
Hen Bob Member
Our fire Marshall was just in a few months ago and said whether your spraying solvent or waterbased the booth needs to be up to code.
But as Mark said I'm sure everyone enforces there ideas differently
11/9/19       #8: Current good quality waterborne fin ...
Mark  Member
Thanks for the info and recommendations;
I plan on having a spray area with fan, filters etc but want to keep it simple (and legal).
Another reason is I do have neighbors within 5-600 feet and I don't want to subject them to the smell of solvent fumes.
And, the reality of it is I'll resist finishing in the first place- I'll be working by myself much of the time, and I'm not that accomplished at it. There used to be a couple of good finishers out here and I'm hoping to re-connect with a few.
As we know, good cabinet work is one thing, but finish is paramount.
11/9/19       #9: Current good quality waterborne fin ...
Mark B.,
It's been my experience that the Fire Marshall and insurance underwriter won't rule on what's in the gun at the moment they walk in. They assume tomorrow you will be switching to solvent based when the next job calls for it. It's like saying I don't need a dust collector because the machine isn't running when the inspector walks in.
11/11/19       #10: Current good quality waterborne fin ...
May well be true. Our insurance and Fire Marshall would never fall for the dust collector/machine not running scenario and they dont really care period what "you say". They deal with whats in place and whats on paper in their report. Insurance isnt going to allow no dust collection period, just aint happening. Fire Marshall (at least here) isnt going to treat an inspected and willingly compliant WB shop the same way they will a solvent shop. They can immediately tell on their inspection based on the type of equipment, volume of solvent, what your work area looks like, and so on, as to what your spraying on a regular basis. As I mentioned, maybe we are lucky.
Here at least they will quickly find out who is trying to skirt the rules with a few frequent stop-in's.
11/14/19       #11: Current good quality waterborne fin ...
Al
David Z,
Do you get the Sayerlack at an SW industrial coatings store? Do you use it as a self seal or use a separate primer?
11/15/19       #12: Current good quality waterborne fin ...
david zaret Member
i get it from a large local branch who gets it from an industrial branch not too far away. i mostly spray clear, and i do use it as self-sealing. sometimes i spray it over stain, shellac, or even cured oil.
i've sprayed the white as well, and i have both used it to self-seal, and sprayed it over shellac-based primer.
2/8/20       #13: Current good quality waterborne fin ...
I switched to water based about a year ago and have been impressed with the results I am getting from Zenith by Axalta. I have a small shop that caters to higher end cabinet projects.
    • Supergrit Abrasives
