Wrong color
1/2/20
Stefano
By mistake i stained black stain (water base aniline dye) plus clear lacquer a small maple table top but I discovered today that it suppose to be white.
I wonder if anyone have suggestion to give me to turn it white. I guess I should send it just a little and than spray the Zinnser white shellac follow to white primer and then white lacquer paint
Thank you
Stefano
1/2/20       #2: Wrong color ...
A world of difference between dyed wood and painted. I suggest you ask the customer! They should tell you to start over with the top.
1/4/20       #3: Wrong color ...
Jonathan Mahnken
White stain? or white paint? if the table isnt pre assembled then sand it back. If assebled then sand with 220 and prime with your favorite primer and paint.
1/7/20       #4: Wrong color ...
Stefano
Thank you for all your suggestions!
Stefano
    • Supergrit Abrasives
