vinyl sealer adhesion
1/25/20
pascal stgelais
Hello everyone.
I have adhesion issue using vinyl sealer.
The wood is bare ash( no refinishing) I sand it to no more than 120 grit since at 150 I get seem to have issues.
The schedule:
-dye
-washcoat(3% vinyl and applied WET since dry coats seems to cause trouble)
- sand with 150 grit(yes 150 since 220 or 320 as recomended by manufacturer cause the next vinyl coat to just lay on top of the stain)
-oil wiping stain
- toner( dye with 3% vinyl one light coat)
-no sand toner
-vinyl wet coat
-CV
1rst question concerns first the wood. I have seen various people recommanding to sand no more than 120. I have also tried raising the grain with before the washcoat to get more grip before the washcoat.
2nd concerns toner should i scuff that coat.and is it ok to make it with viny since my CV dont like thinning
3rd I have been able to get good results so far but always end up with a more fragile finish when staining than barewood selfseal. is it normal(the result is still pretty hard though)
1/25/20       #2: vinyl sealer adhesion ...
Jim Clark  Member
That oil stain can be a problem if it's not
thoroughly dry.
I give it several days myself.
I sand everything to 220 grit and
spray wet. Haven't had any problems yet.
I do thin my sealer 50%, which is a lot but
it lays better and gets in the wood better.
1/25/20       #3: vinyl sealer adhesion ...
pascal stgelais
Regarding the stain it is supposed to be able to be topcoated after 1 hour (mohawk) although i prefer to wait until I cant smell the mineral spirit/paint thinner sent.
when it is dry do you scuff sand the stain?
regarding vinyl sealer the pds sheet state no build limits other than the total system but I suspect that building it too much is the problem because to rule out stain I applied cv directly over the stain after like 30 min when it still smelled oil and no failure.
I used to Dye-washcoat-stain-vinyl seal-vinyl toner-vinyl seal and by the last vinyl seal coat it became very fragile. Or if it seems good as soon as the first coat of cv gets sprayed the finish gets brittle
Even if the manufacturer give no limit when reading similar products from other brands most state a 0.5 to 1mil MAX thickness.
so regarding the vinyl am I right trying to apply as less as possible.
If I try the following schedule :
dye
washcoat vinyl 3% solid
sand
wiping stain
sand or no sand ?
vinyl toner 3% solid
sand or no sand?
normaly here I applied a full solid coat of vinyl but it always ended up fragile. should I just go with CV after the toners. this woild result in just 2 coats of vinyl sealer 3% wich would result in a minimal build
1/26/20       #4: vinyl sealer adhesion ...
mastercabman
Your schedule sounds complicated!
1/26/20       #5: vinyl sealer adhesion ...
pascal stgelais
I know thats why I am trying to simplify it as much as possible. I will try to put thw toner color directly into the topcoat wich will eliminate a step and thus reduce overall build
-dye
-vinyl washcoat 3% solid*
-sand
wiping stain
-CV (tinted with transtint dye)
*although my ash doesnt really blotch this step help bind the dye because if I apply the stain and wipe it directly over the dye I end up removing some of the dye.
the 3 color steps is the only way I get statisfying results because neither alone seems to do it
1/26/20       #6: vinyl sealer adhesion ...
cabinetmaker
Are you catalyzing the vinyl ? And, why the dye over the oil ?
1/26/20       #7: vinyl sealer adhesion ...
pascal stgelais
the wood is dyed FIRST
then washcoat
then oil wiping stain
the vinyl is not catalyzed since the manufacturer told me strictly to not catalyse the vinyl even with catalysed finishes. They manufacture no catalysis for it and trying to catalyse it with any product would be detrimental.
I am now trying different grits when sanding the vinyl sealers because sanding it with 220 as they recommand might not be coarse enough. I will try 150-180-220 on a test board
1/26/20       #8: vinyl sealer adhesion ...
Unless you are experiencing blotchy staining why are you applying a vinyl coat between the dye and the stain. Unless they are the same resin base the stain shouldn't move the dye around (melt it).
So it should be dye, stain, vinyl sealer no thinning (catalyzed if using a catalyzed topcoat) scuff, topcoat, scuff, topcoat done.
1/26/20       #9: vinyl sealer adhesion ...
pascal stgelais
thanks for your answer leo
I am currently testing your schedule but wil change the EZ vinyl sealer for a conversion sealer( both mohawk).
maybe the problem is there. I have asked the question to 2 diff. person at mohawk ( 2 phone 1 email) and they all confirmed that this vinyl sealer MUST NOT be catalysed even under precat/postcat/CV. No catalysis exist for their vinyl sealer.
anyways this vinyl sealer as always been problemating since it always ended up brittle and easy to scratch/flake whether I sprayed it wet/dry/unthinned/thinned. Somehow sometime I was able to endup with a hard vinyl coat.
anyway as stated I will be receiving mohawk conversion sealer and will try it. It will then be a catalyzed sealer topcoated with catalysed topcoat. So my routine will be:
dye
oil wiping stain
conversion sealer
sand
CV mixed with transtint dye (as general toner)
I will probably put mohawk reducer retarder 5% in sealer/topcoat since my ash seems to bubble a lot.
1/29/20       #10: vinyl sealer adhesion ...
Matt
You may be applying the stain too heavily. This is the only thing I've encountered in my finishing life (since 2004) that predictably can cause adhesion issues.
I suggest you skip the vinyl sealer altogether and just use a good stain and conversion varnish.
If the stain isn't coming out dark enough, wipe the surface of your product with a wet rag just enough to raise the grain (make it fuzzy). Let the water dry off and then stain your product. The stain will end up MUCH darker and much less blotchy.
Don't use an oil stain for this. Use a common industrial alkyd resin stain.
Let the stain dry for a good 2 hours and follow it with 3 full coats of conversion varnish. No sanding sealer, no vinyl sealer needed.
Scuff sanding the first coat of conversion varnish will be a bit tedious if you used water to raise the grain but the second coat will sand as flat as glass if you have good sandpaper.
As long as you're using a good quality conversion varnish, self-sealing is usually going to adhere better.
1/31/20       #11: vinyl sealer adhesion ...
pascal stgelais
I have solved my problem. at least partially.
I have ordered mohawk conversion sealer. I have tried 2 schedule :
-dye
-wiping stain
-conversion sealer
-conversion varnish tinted with dye
-dye
-wiping stain
-vinyl toner (thinned to about 3% solid)
-conversion sealer
-conversion varnish(untinted)
now regarding resistance the first one seem to have an edge over the second but the second one yield better results.
I think I was applying too thick of a wet coat. I bough a glass piece and mesured my wet coat on it since it doesnt absord the liquid.
I ended up spraying almost 3 4 semi-dry pass to get a good wet coat and avoid spraying too thick
10/4/21       #12: vinyl sealer adhesion ...
LillianShar
When we apply the new material, it kind of repeats the contour and geometry of the old material. Or the wood itself, as in your case. Therefore, it's essential that when sanding, the surface is free of defects. This is why you need to smooth the surface to 120 grit. You can read more about Seal With Ease; maybe some sealers work well with 150. I don't have one of those.
For one thing, I don't apply them. It's mostly more to MDF surfaces. On hardwoods, that kind of sealant doesn't work. In any case, the adhesive needs to be applied to a clean, degreased, but not wet surface.
Seal With Ease
3/21/22       #13: vinyl sealer adhesion ...
jizzy
It all depends upon the quality of the wood you are going to use mate!
    • Supergrit Abrasives
