Sanding beween Coats
1/29/20
Garen Member
What do you use to scuff in between coats?
Normally I spray conversion varnish. Either Chemcraft or S.W. Spray vynal sealer and topcoat. The Sherwin Williams I always have an issue with it laying down perfect. I liked the Chemcraft but the hardness seams to take a long time to get where it should be compared to the Sherwin Williams. As for sanding in between coats I use a fine sanding sponge. I thin its to course and I seam to get shit always in my finish. Spraying with a AAA 15-1 graco.
1/29/20       #2: Sanding beween Coats ...
I sand with several different products. Flat areas like door stiles and panels I use a Mirka Deos sander with their Ceramic 320 grit paper.
I also use sheet paper on a block that I've glued some felt on. Again 320 grit.
Mirka Gold Soft is another I use. Usually for curves and profiles. Again 320 grit.
Mirka Mirlon woven, maroon. Use this mostly for profiles, especially when I'm putting the last coat on where it's not necessary to knock off nibs because you've done that the last coat and the 2nd to last coat should mostly be smooth already and just needs a little tooth.
1/30/20       #3: Sanding beween Coats ...
320grit products between top coats. Like Leo we use a variety of things. Sponges, abarnet discs, psa paper stuck to a block.
The key is to sand when it’s not going to clog the abrasive. 240grit is too coarse. You will see the scratches in the final coat. All you are trying to achieve is the removal of that gloss & dust. You can go higher in grit without it affecting adhesion but it’s slow. 320grit is the number
1/30/20       #4: Sanding beween Coats ...
320 foam backed SiaSoft
1/30/20       #5: Sanding beween Coats ...
Jonathan Mahnken
Custom sanding pads on orbital sanders, soft blocks and sponges, scotchbrite, and by hand. after first coat is 220-240 so much faster if you "have the touch". 320 between 2nd and third coats.
    • Supergrit Abrasives
