Bar/ tough finish
2/2/20
G Member
What is your favorite bar/area you need a good hard finish without using epoxy/thicker coating. I have been using conversion varnish and looking for more durable ideas. People always are concerned right away with the CV not to full strength yet when installed. Have been using SW and have tried Chemcraft. Chemcraft seams to take a little longer to achieve full strength then the SW. Any thoughts let me know. Thanks
2/2/20       #2: Bar/ tough finish ...
2K Poly. As far as I have noticed 3 days is more than enough cure for strength and by then is no smell.
2/3/20       #3: Bar/ tough finish ...
Tyler
2k poly over a polyester sealer has never let me down, some brands have a 48 hr cure, some are closer to a week. But it always smells less than CV.
2/5/20       #4: Bar/ tough finish ...
dar
2k poly or 2k acrylic which is better for bar top?
2/5/20       #5: Bar/ tough finish ...
chris
if you dont want a slightly golden tint then use 2k acrylic.
acrylic is non yellowing but costs more
2/8/20       #6: Bar/ tough finish ...
dan shaf Member
Conversion varnishes achieve 80% of their cure after three days, the rest of the remaining 20% takes another 3 weeks. Precat lacquers, for example, take the full month to cure to any appreciable durability, but still not enough for a bar top (in my opinion).
    • Supergrit Abrasives
