spray paint lighting
2/12/20
Edward P Smith Member
Website: http://www.cottagesmith.net
When I am spraying I have plenty of light but sometimes I can see the fan coming out of the gun and sometimes I can't. Most threads talk about color and visibility, but what is the best lighting angle to see the mist coming out of the gun? When I can't see it my overlaps are not right and I get stripes.
2/13/20       #2: spray paint lighting ...
Shane
Learn to work with what you have..... Your typically going to tilt your head to catch the " Raking light" so you can see your wet pass laying down...
2/13/20       #3: spray paint lighting ...
Raking light is what you are referring too. A light at a low angle to the work piece will let you see the liquid paint better. Only because you can see the light source in the reflection.
2/13/20       #4: spray paint lighting ...
dan shaf Member
Same issue for me. Especially white on white. Posturing (bending down) is sometimes possibe, but to do that for a rack or two of door & drawer panels can be taxing for me. I just started playing around with led lights. I forget what I bought, I think it's a 9,000 lumen soft white (yellowish, like an incandescent). It's approximately 4' off the ground, approximately 6' behind me off at an angle, like over my right shoulder. I'm right handed. My turntable/spraying table is right in front of me.
For panels and flatline objects, I only need this light behind me on. For anything that's shaped, or a casegood or cabinet, I also use the boothlights and I set up another LED light , this other light is on the left side, also at 4' off the ground.
The better design for booths is to include side lighting.
Sometimes, all you can do is not where your fan is aimed, know the shape of your fan and the quality of the atomization,, know how high your gun is from the surface being sprayed, plan how fast your pass will be, and know where your pass is by how your arm is extended. Spray square to your surface and pretend you are a robot sprayer. It's like driving on the highway in whiteout conditions during a snow storm.
2/14/20       #6: spray paint lighting ...
dan shaf Member
Here's my lighting setup.
2/15/20       #7: spray paint lighting ...
Thank you guys, for your advice. I will experiment with raking light. I remember a shop I worked in had side lights but I never sprayed in it. I can't wait to try it. Now, what do I do about the stripes? I think I had too much fluid passing through the gun, or in the center of the fan. I use a Maxum Elite II.
2/15/20       #8: spray paint lighting ...
dan shaf Member
To fix striping, scuff sand or go further and cut down the finish, and then recoat.
2/15/20       #9: spray paint lighting ...
rescraft
If you've ever seen a shaping bay for shaping surfboards, they have all their lighting horizontal and at the height of the blank they are shaping.
Of course the white color of the foam is flat, making it very difficult to keep the surface curves consistent. The light flows over the blank, showing every imperfection.
    • Supergrit Abrasives
