Gel Stain
3/5/20
Rusty Statham Member
Is anyone making their own gel stains? If so, what are you using for the gel medium? I like having the ability to "rub in or rub out" the finish to achieve the desired color. I would like to make my own custom colors for my projects and not have to rely on big box stores with limited colors.
3/5/20       #2: Gel Stain ...
Daniel Berlin
I spray stain for the most part.
There are some manufacturers that make gel stain bases (ilva makes one, for example).
When I have wanted to make gel stain, i usually just take a fairly neutral color in a gel stain that exists and add compatible dye or pigment, depending on what i'm after.
For example, take general finishes white gel stain and tint it a little or whatever.
    • Supergrit Abrasives
