Lint in wet coat
3/20/20
JM
Hey all.
I have a problem that i can't solve. When im spraying opaque finishes the whole piece will look great except for a few "goobers" catching my eye.
I look closer and i see that they are little hairs. Not human hairs as those are too thick. These are tiny fibers that appear to be from clothing.
So i started wearing a plastic overall jump suit to protect my product from my clothing.
I would still see these little fibers. I wasnt wearing the suit when mixing up my finish so i thought ah this must be it.
Started wearing the suit when mixing and spraying.
Same result.
Im double filtering into final can where i use a AAA pump that has a line filter on the pickup. The gun also has a micron filter in the handle that i clean weekly.
Not sure what my problem could be.
Anyone else have this "lint/fiber" issue? And were you able to fix it?
3/20/20       #2: Lint in wet coat ...
Jim Clark  Member
Sometimes build-up around the tip of a
spray gun can cause what looks like little
fibers when they let loose and land in the finish. Keep a watchful eye while you're
spraying and look for any build-up.
Some painters constantly wipe the spray
tip with a lacquer soaked rag while spraying.
(just a thought, it could be many things)
3/20/20       #3: Lint in wet coat ...
Another option could be static electricity from wiping the parts vigorously before spraying. They could be there before you suit up and mix or spray.
3/20/20       #4: Lint in wet coat ...
I would check your makeup air. Depending on the filters you could be pulling some fibers off it with the exhaust fan.
3/21/20       #5: Lint in wet coat ...
The post cat finish I use builds up a static charge when blowing off dust after scuffing. I was always getting fine cotton threads landing in the wet coat. I bought coveralls with anti static threads and wear them for spraying. Problem solved.
3/21/20       #6: Lint in wet coat ...
SteveL Member
I agree its static. It gets worse for us in the winter, we get extremely dry. Trying to add humidity helps but is near impossible to keep up with the air flow.
Finally I bought an "ion gun" and it has made a difference. These things are expensive but I bought one on amazon for around $200 just as an experiment and it seems to work.
3/21/20       #7: Lint in wet coat ...
Shane
I've dealt with static cling on high gloss finishes in the cold seasons by actually using dryer sheets as a final wipe down with no ill effects on the finish... worked like a charm.....
3/21/20       #8: Lint in wet coat ...
JM
Wow! Never gave static charge a thought. I'll try the dryer sheet idea next time.
There are overalls that can be static free? Forgive my ignorance but could someone point me in the direction of purchase?
Thanks everyone for the input!
3/21/20       #9: Lint in wet coat ...
Jim Clark  Member
I've been using Endust on a shop rag for
tacking all my parts, it removes dust better
than a tack rag and removes the static.
I have been using it on all my car bumpers I
paint for the past 15 yrs and never had
any fish eyes or anything else that everyone
seems to worry about.
Wether it's wood, plastic or metal, Endust
has worked best for me.
3/21/20       #10: Lint in wet coat ...
The coveralls are E-Z Mix brand. They are well made and fairly cool to wear with vents and pockets. The material has carbon fibre threads to dissipate static.
The bonus is I don't go home reeking of lacquer.
