Diaphragm spray pump
4/12/20
Al
I quite often use finishing materials from Conestoga. Stains, topcoat, etc. They recommend using a diaphragm pump to spray their topcoats. I have an airless that is diaphragm type but it is intended for waterborne or oil base type paints .Can someone point me towards a diaphragm pump designed for more solvent finishes like we use? I did use the one I have and it laid the material out beautifully but the solvents were hard on the seals.
Thanks,
Al
4/13/20       #2: Diaphragm spray pump ...
Nick
Graco, Binks, CAT and Wagner all make diaphragm pumps and all offer pump packages that include hoses, spray gun and regulators.
Graco 308, Binks Gemini, Wagner Zip 52, l don't know what CAT calls theirs.
Make sure whatever set-up you get is outfitted with a low pressure fluid regulator.
4/17/20       #3: Diaphragm spray pump ...
Al
Thanks Nick. Doing some research I see Wagner makes one called Cobra which can be used with a hopper. This would be perfect but it is a little pricey.
9/8/20       #4: Diaphragm spray pump ...
Denny J
Just get a Titan 655. It has a hopper and I am running three in my shop. Good little sprayers for the money. The Cobra is fantastic if you do high volume in a shop setting but it can almost be overkill in many situations
    • Supergrit Abrasives
