Gray dye stain
4/14/20
scott brady
Looking for suggestions for staining Quarter sawn white Oak veneered panels with a medium grey transparent color. Any easy solution besides going the steel wool / water method. Thanks for suggestions.
4/14/20       #2: Gray dye stain ...
Matt Calnen
I like to mix egg whites, turpentine, and alittle yellow glue together. Just put them all together in a bowl, whisk briskly until well mixed, then liberally apply. After 5 to 10 minutes, wipe down and you will be amazed a how nice and grey your project looks, no need to do a test sample, this recipe works every time. Enjoy!
4/14/20       #3: Gray dye stain ...
Chris
Check out WD Lockwood stains.
Have a good selection of dye stain colors
4/15/20       #4: Gray dye stain ...
mauricio poli Member
Some days ago I match a panel using this schedule:
1 - wash coat
2 - light grey wiping stain, clean well, dry well
3 - sand
4 - grey NGR stain
5 - sealer, sand
6 - top coat
It gets a light grey inside the poros, very modern color.
    • Supergrit Abrasives
