Need help chaulking with solvent CV
5/5/20
Jim
If I have a cabinet door, and I wish to chaulk a mdf panel where it meets the style and rail. I havent found the right chaulking. My water base chaulking and my solvent base CV don't play well with each other! So I tried letting the chaulk dry, then seal with shellack one time and vinyl sealer the next....still cracks. So I need some advice for a winning compatible method.
Thanks jim
5/5/20       #2: Need help chaulking with solvent CV ...
mastercabman
First thing first
It's caulk not chaulk
Second,why do you caulk the center panel to the rails And stiles?
I never do and I don't know any manufacturer that does
The center panel needs to move freely
CV is a hard finish and will not move with the flexibility of the caulk
However I do use caulk on my crown molding and other trim
I use phenoseal when I do
Seems to work but molding is usually glued and nailed so it doesn't move as much
5/5/20       #3: Need help chaulking with solvent CV ...
scott brady
Jim we do caulk our doors and have had no problems as far as cracking. We use DAP painters acrylic latex caulk, let dry for 24 hrs., than prime with ML Campbell clawlock primer; sand and 2 coat of CV.
5/5/20       #4: Need help chaulking with solvent CV ...
shenendoah
Jim,
Do not use 5 piece construction then. Go full MDF/HDF routed on a cnc.
6/18/20       #5: Need help chaulking with solvent CV ...
Shane
I'm with Shenendoah..... 5 piece? keep you coatings thickness at bay and dont bridge any ugly gap where seams are or if you want seamless use MDF full CNC doors..
    • Supergrit Abrasives
