Apply Epoxy or wood glue on the end grain before finishing my sign
5/13/20
Jenny Member
I am making an indoor sign with several kiln-dried 7% glued-up quartersawn wood boards. I plan to finish them with solid-color 2K Poly.
Since the end grain tends to suck up more moisture comparing to other parts of the board, would plugging the end grain with marine epoxy/Titebond before finishing make the moisture fluctuation more even across the sign?
If so, when should I plug the end grains?
- the moment the boards got delivered to my shop; or
- After the boards acclimated in my shop for 3 days; or
- right before I spray the boards.
I am trying to make sure my sign does not warp/cup/twist in the future.
5/13/20       #2: Apply Epoxy or wood glue on the end ...
duster
If you're finishing your indoor sign with solid color 2k poly, why are you making the sign with solid wood? MDF would be a better, cheaper, and less time consuming material to use. No boards to joint, rip, and glue up. No panel to plane and sand. No danger of the panel cupping, warping, or twisting. Not to mention, also a better surface to paint.
5/13/20       #3: Apply Epoxy or wood glue on the end ...
Jenny Member
Hi duster,
I agree with you that MDF is a better choice for the project. However, the person I’m making the sign for doesn’t want MDF.
This is why I am making a sign out of solid wood. I am trying to decide if I should seal the end grains with Epoxy before finishing with 2K Poly.
5/13/20       #4: Apply Epoxy or wood glue on the end ...
duster
Ok, we've had this discussion before. If your customer is an anti-mdf snob then go ahead and use whatever material they want. I hope you're charging for the 4x extra labor involved.
Sealing the end grain before finishing will not make your panel more stable. Your 2K poly finish will seal it just fine. Sealing the end grain before finishing with glue, paint, or whatever will allow you get a smoother final finish on the end grain, but that all you can expect to achieve. It's not going to magically make your panel more stable.
    • Supergrit Abrasives
