painting MDF
5/25/20
Jim Member
Looking for tips on spraying BIN shellac primer. I have a 4 stage HVLP. Thank you
5/25/20       #2: painting MDF ...
Keep a rag damp with denatured alcohol and wipe the tip/nose piece often. It drys very quickly and will clog. This causes sputtering.
5/26/20       #3: painting MDF ...
One thing I learned. When sealing MDF with any primer make the first coat light barely clouding the surface. Let it dry then come back with a heavier seal coat. Otherwise the finish will soak in regardless of how much you apply.
6/1/20       #4: painting MDF ...
Robert M  Member
Jim, with very delicate & much respect to you ( and any shellac "fans") , this is one product you'll hardly "if ever" see in most if not all.....true pro shop !!
There's many company ( like any AkzoNobel ((Valspar.) or Milesi...to name a couple !!) are making acrylic sealers. ( not to say, some even make there own in house with old or left over on shelf lacquers !!
Much more user "spray" friendly....to say the least.
Check arround from your best local "pro" product supplier.....
Although, and this is no a contradiction....shellac can make a great result, but ...why hustle with this when simpler & easier can be done ?!?..... ;0)
Sheers and all the best !!
    • Supergrit Abrasives
