No-bleed stain on plywood?
6/6/20
Oggie Member
I need to stain a chess board pattern on plywood, with darker and lighter tones for dark and light squares, while keeping veneer grain visible.
Is there any type of stain (gel maybe?) that will leave crisp, clean lines after I peel of masking tape instead of having hairs of stain bleeding with the direction of wood fibers?
Maybe some transparent primer before staining?
Thank you,
O.
6/6/20       #2: No-bleed stain on plywood? ...
pascal stgelais
hi
although I haven't tested it myself I have seen videos on youtube about gel stains leaving very sharp lines.
I dont remember if it was on solid wood or plywoos though
6/7/20       #3: No-bleed stain on plywood? ...
Jim Clark  Member
I think you would be best off to spray a stain.
6/7/20       #4: No-bleed stain on plywood? ...
DannyB
A few options worth trying in order of ease
1. Spray stain
2. Add the stain color to a little finish and spray that
3. Put on a sealer coat, then do #2.
6/7/20       #5: No-bleed stain on plywood? ...
Colored finish is about the only way you are going to make that fly.
I'm making some assumptions here, that you'll have a natural colored wood and a darkened wood to make up your chess pattern.
Spray a clear coat on your chessboard surface, maybe two depending on how much build your finish has. Mask off the squares that will remain clear coated. Mix up some dye with your clear, the color you want for the dark squares and spray it on until you get the color depth you want.
Unmask and continue spraying with clear and scuff sanding until you have a flat finish, clear of lines from the tape.
It's probably best that the colored finish is very thinned out, a toner, just to impart color but have very little build.
6/7/20       #6: No-bleed stain on plywood? ...
rescraft
Use frog tape, and moisten with a sponge, after applying, to activate the adhesive at the edge to prevent bleeding.
6/7/20       #7: No-bleed stain on plywood? ...
Mastercabman
I got a feeling that the OP is using a single piece of plywood vs individual square pieces
And trying to mask off to create the chess board?
If so that's going to be challenging!
6/9/20       #8: No-bleed stain on plywood? ...
Oggie Member
So, it looks like the only sure way is clear coat before stain.
Stain on top of bear wood usually accents the grain, but I suppose that will not be the case on top of clear coat.
I've seen some guy on Youtube using masking tape and then score the surface with utility knife along the edge of the tape, to stop the bleeding. It worked but it leaves scoring lines.
Wonder how would it looked if the scoring lines were filled with finishing agent and everything leveled out at the finishing coat.
Maybe it would not be noticeable.
Will try that just out of curiosity.
I hate to get my spraying gun dirty for such small projects :)
Thank you all for your valuable advises and opinions!
O.
    • Supergrit Abrasives
