Automatic oilers for Dynabrade/Air sanders
8/17/20
Matt
We used to manually oil our air sanders with a drop or two of oil each day but we recently just replaced all the quick-disconnects with threaded inserts, so unscrewing them for oil isn't something I want them doing daily.
Plus, it's an easy thing to neglect.
I'm looking for options on automatic oilers that can handle enough airflow for up to 3 sanders at a time (the common 5" dynabrade orbitals).
Can anyone make a suggestion? I've never bought an auto-oiler and I can imagine they can be a bit finicky. I'm hoping for somethat that only requires occasional refilling and not constant fiddling.
The supplied air is dehumidified, by the way. 100psi.
8/17/20       #2: Automatic oilers for Dynabrade/Air ...
herb johnson
just a suggestion, you would need an oiler with about a 60cfm flow but how would you know that all of the three sanders are getting lubricated equally in a manifold situation three outlet, not trying to be a pia but what about getting full flow qds and hitting each one with oil., just a thought i use full flow qd's so that my sanders don't give me swirls from the pressure drop thru conventional qd's
good luck herb j
8/17/20       #3: Automatic oilers for Dynabrade/Air ...
I have a pneumatic paint shaker that I use an oiler on. You can vary the oiler to almost nothing to a flood and all points in between. There is a site window that lets you see it deliver the oil.
I would suggest an oiler per sander to make sure you get the proper oil to each sander. They're not that expensive.
Pneumatic Oiler
8/18/20       #4: Automatic oilers for Dynabrade/Air ...
Shane Welch
I'm with Leo... Put an oiler as close as you can to each tool so your not further contaminating your lines with oil just in case you shift your work area situation around. If all of a sudden your work area requires clean oil free lines your good to go.
8/18/20       #5: Automatic oilers for Dynabrade/Air ...
They have small inline oilers but I find that they break easy. And I don't know how, they look like they're built very well. But I've had a few of them and they just don't last.
That's why I got the big oiler.
8/18/20       #6: Automatic oilers for Dynabrade/Air ...
Shane Welch
I guess I meant to say close... but not inline with the tool.... just somewhere on the mainline before the hose so your not oiling every inch of the pipeline... that way if some paint equipment needs moved around and used you dont have contaminated lines in that area.
8/18/20       #7: Automatic oilers for Dynabrade/Air ...
I was just throwing another option out at him. Definitely keep the oiler off the main line and only have it on the individual sander line. That way if you have to swap out you can toss the hose, put a new one on and be on your way with little contamination from the oil.
Like you said.
8/20/20       #8: Automatic oilers for Dynabrade/Air ...
Joe Knobbe
Matt, can you add a quick disconnect further upstream that they could use to add a couple of drops of oil each day?
