color shades different on jobs
9/8/20
Frank
we have been in business for 49 yrs...myself 33 yrs. we are getting big problems with frames, molding, doors not matching the same shade of color using SW waterbased finish.
this is a huge repeating problem. i tried stirring, etc...right now we are thinking the millage is different on each item and it may be making the color come out different.
any of you guys can guide me to a solution..this is huge as we do 4 big kitchens a month. i'm even thinking of switching based to oil based top coat. really @ wits end.
thanks guys
frank
9/8/20       #2: color shades different on jobs ...
MAURICIO POLI
Hi !
Can you apply all the pieces together ?
In order to have the same quantity of color?
Or maybe you need to ask SW to sell you the same color with more hidding power, more pigments...
Good luck
9/9/20       #3: color shades different on jobs ...
Eddie
We had this problem when the guys were spraying the cabinets upright, limiting the mills because of the runs. We solved that by spraying everything laying down so the mills are the same for doors and boxes. Regarding the crown molding, remember that just by setting the crown on top of the cabinet with the projection, it may change the shade. We always box our top coat paint and always pay very close attention to the final coat, to make sure we have enough product. Buy a extra gal. to finish the project will be a "no" "no" to us. Good luck.
9/9/20       #4: color shades different on jobs ...
Frank
thanks for the replies. we ran all combo's of water based and combos of old oil based cv.
hands down coverage is better on the Sherwin W oil cv. its not even a contest. i really wanted the WB to be an equal but to me currently its not and i'm very progressive. speaking of progressive we seem to be settling on top coat self sealing then light sand to 2nd top coat. its an amazing improvement.
9/15/20       #5: color shades different on jobs ...
John Bishop Member
Which SW product are you using? I have used their Sayerlack waterbased with good luck, but you do need to occasionally stir if a big spray job.
    • Supergrit Abrasives
