CV mixing by volume or weight ?
10/26/20
Tom Gafgen
Do most of you mix by volume or by weight ? I've been mixing by volume for 20 years with never a problem but have recently switched to a new type of pail liner to mix in which is making it difficult to read my measuring marks on the pail accurately .So I am considering switching to the weight method which I'm sure is dead on accurate and I guess my question should be How accurate does the 10%catylst ratio have to be ?Would being off by 1% either way cause noticeable problems ?
10/26/20       #2: CV mixing by volume or weight ? ...
gralyn Member
what we did is cut a slot into a sacrificial pail vertical that will act like a window to see the liner. leave the pails rim intact . add your graduation marks on the pail. This option has worked well for me.
10/26/20       #3: CV mixing by volume or weight ? ...
Jim Clark  Member
It doesn't have to be that accurate.
I have varied mine a lot depending on
the temperature.
10/26/20       #4: CV mixing by volume or weight ? ...
Jim Clark  Member
Most measuring cups aren't that accurate either, in fact some are quite a bit off.
10/26/20       #5: CV mixing by volume or weight ? ...
Shane Welch
we use pail liners to mix quickly for less than 5 gal. batches.... We made stir sticks from aluminum bar with graduated lines on the stir stick to reference how much material is poured into the liner... marks at 1 gal, 2 gal, 2.5 gal, 3 gal etc etc... strain and pour material up to the line... then we always measure catalyst in a small graduated plastic mixing tubs we have handy and just give them a little rinse .. that way at least the catalyst is measured fairly close... Quick n easy
10/26/20       #6: CV mixing by volume or weight ? ...
DannyB Member
Mixing large amounts by weight is a pain in the ass for a number of reasons.
Like others, i wouldn't bother.
Acid-cured CV is not particularly sensitive about catalyst.
The main issue if you add too much is you'll end up with white particles in the finish - this is the catalyst that is not used up.
The only thing i mix by weight is small batches of stuff that is more sensitive to catalyst amount.
10/27/20       #7: CV mixing by volume or weight ? ...
Tom Gafgen
Thanks for the responses and good ideas and also for confirming that there's no reason to switch to the weight method , I think that would have been a pain .
10/27/20       #8: CV mixing by volume or weight ? ...
Shane Welch
not to mention a scale that can handle that sort of weight accurately is $3k... lol.. I know.. We have one for mixing paint colors with Sherwin's tint system for opticolor...
10/27/20       #9: CV mixing by volume or weight ? ...
DannyB Member
I was actually just gonna say that - a nice accurate scale for that is thousands, and good luck getting one that is meant to be around lots of solvents.
11/10/20       #10: CV mixing by volume or weight ? ...
Y.Heller Member
Buy scientific lab graduated cylinders for the catalyst.
Plastic cylinders read straight across the graduated line while glass reads to the bottom curve of the meniscus. There can be a degree of error in that reading based on your viewing angle of that curve/ who’s looking at it and what they read it as. And obviously the plastic ones are far more durable than the glass.
The plastic cylinders come in different types. There is PPCO which is a cloudy clear plastic and PMP which is entirely clear like glass. For highest accuracy you’re looking for Class A bit they also come in Class B which has a higher degree of error.
The Class A are somewhere around $20.00.
11/10/20       #11: CV mixing by volume or weight ? ...
Y.Heller Member
Correction. They’re around $40-45 for a 500ml (16oz). Price vary by size.
12/22/20       #12: CV mixing by volume or weight ? ...
Jim
Y Heller
That sounds very good. So where you go to purchase?
Thanks !
    • Supergrit Abrasives
