Varathane Stain
11/12/20
scott
Had a customer that brought a stain sample on bamboo that looked good. Varathane Premium Wood Stain, don't know much about this product, looking to finish off with Krystal Conversion Varnish. Any forseeable problems i should be aware of?
11/12/20       #2: Varathane Stain ...
Mark Member
I had a customer supply Varathane stain not too long ago. It's what is sold in our local big box home improvement store, (menards). Comparable to a Minwax. The end product looked nice (on birch) but I found to get the actual color they wanted you had to put it on heavy and pretty much had to leave it on until it was almost dry. When sprayed with CV the solids seemed to be brought up from wood. I didn't like it, had a rough texture when dry, took a few more coats than usual to get a smooth finish. The very next job after that the folks had a stain match that was spot on to the same color but using a gemini stain, much nicer to work with.
11/14/20       #3: Varathane Stain ...
We encourage people to find a Minwax flavor. MLCampbell makes all of them in their super high quality Woodsong line of solvent based stains.
It’s not unheard of an Architect to spec a Minwax stain color.
I’ve never used the Varathane. Minwax is terrible. If I need to do a small stain job I will use the Zar brand. It’s decent.
    • Supergrit Abrasives
