UV finishing for small shops
12/7/20
Paul Miller
Website: http://WWW.MCCWOODWORKING.COM
I am trying to find information about using UV finish products for my cabinets and moldings. Mine is a small shop, not high volume at all. Has any one out there used UV products, other than the large shops?
12/12/20       #2: UV finishing for small shops ...
masterblaster
won't work for you.
12/14/20       #3: UV finishing for small shops ...
JeffA
Paul,
The easiest you could do is to get a used flat line. Waterbased UV dries and cures in about 15 minutes. And at 8 ft/min you will need at least 120 feet just to start for a line that will do both moldings and cabinet parts.
12/15/20       #4: UV finishing for small shops ...
Paul Miller
Jeff, that wouldn't work in my shop. Why would you use a water based UV vs 100% solid? I picked up a handheld light and I'm thinking an enclosed light with a conveyor would work. My motivation is that I think the UV finishes are superior to pre-cats or conversion varnishes. Do you have any experience with UV finishes? It seems clear to me that these UV finishes are the future for all shops.
12/15/20       #5: UV finishing for small shops ...
DannyB Member
UV finishes are unlikely to be the future for all shops for a long time.
For cab shops, maybe sooner.
They are nice but expensive, and have their own issues and serious dangers.
If you are high volume, it's great.
if you are not, not gonna be worth it for a while
They also are not necessarily any faster/easier for more complicated furniture.
(though they are more durable, but that's rarely an issue except for flooring/cabs)
Compare trying to spray a complicated piece and let it dry for a bit (and being done) vs spraying a complicated piece, letting it dry for the same time period, and then trying to ensure you shine light on it in all the right places for the right amount of time.
It's hard to see the benefit.
Yes, it cures instantly instead of say, 3-7 days. But it's not clear that actually saves any time in the end in a low volume shop.
(IE is it really going to get to the customer any faster and does it really matter to them)
12/17/20       #6: UV finishing for small shops ...
JeffA
It's almost impossible to spray 100% solids UV. First off its too dangerous health wise and secondly you can't spray that accurate. Thats why 100% solids are vacuumed coated. I have never witnessed it done by spray. Not saying it isn't but you can't do it by hand.
And yes, I have had a few years of experience with UV finishes. Both 100% solids and WB spray UV.
12/19/20       #7: UV finishing for small shops ...
dave c
My understanding is a decent UV lamp process starts at 80K and requires some space. That's from a guy who sells them.
