I hope this isn't a dumb question
1/5/21
mauricio Member
How is spraying paint different than spraying lacquer? with an airless
1/5/21       #2: I hope this isn't a dumb question ...
Mark Member
I spray CV with an airless and you'll need smaller tips than what you would use for paint. I prefer the Graco Fine Finish (green) tips.
1/6/21       #3: I hope this isn't a dumb question ...
No such thing as a dumb question here.
It might seem dumb if you have never done something before, but we all had a first time at doing something.
Like Mark said, basically you would use different size tips based on the viscosity of the product you are spraying, you would have some variances in surface preparation and you may prefer different kinds of equipment for the product you are spraying.
The location of where you are spraying quite often dictates the equipment you would use as well. In a shop with a clean dedicated air supply I like to use an air assisted pump for spraying lacquer, I have used a few brands but prefer the Kremlin, on site it is harder to use that pump because you require quite a bit of air. I don’t do much on site spraying anymore, but when I did I liked to use an airless pump, my favourite was a Spraytech, it was good for paint and for lacquer.
Anyways you can talk to others , or a good resource is the suppliers of the product you want to apply, they will help you out.
1/6/21       #4: I hope this isn't a dumb question ...
MarkB Member
When you say paint do you mean latex house paint? And straight airless or airless air assist?
    • Supergrit Abrasives
