Sher-Wood CV
2/9/21
Eric
The current CV that I have been using has been great until recently when they decided to modify the formula causing a lot of headaches. They said eventually they will go back to the old formula but until then I thought it would be a good opportunity to try new products.
I talked to Sherwin Williams and they set me up with Sher-wood HB Pigmented CV for color and have been using Sher-wood Water White CV as top coat over paint and stain. I have been thinning the HB CV 30% with the recommended reducer by them and sprays out really nice, and sands pretty good to. Has anybody here used this Sher-wood HB CV and can share there experience with it both good and bad. So far I only sprayed a few samples and a small vanity with it.
Also, to those that have used Sher-wood WW CV one complaint I have had in the past from clients is their cabinet interiors smelling from the formaldehyde off-gasing. How bad is this stuff with off-gasing and eye-burn? Anybody have problems, tips or tricks with this stuff. Seams to spray out nice, though dosn't seem quit as durable/hard as what I was using.
I noticed there is a Kemvar, Low formaldehyde kemvar and F3 formaldehyde free Kemvar version. Would anybody recommend any of these over the WW CV, and why?
    • Supergrit Abrasives
