Refinishing
5/2/21
Charles Kimball Member
I have a request to refinish a nice stain grade hutch that is prolly around 50 yrs old. In keeping with trends, they want me to shoot it with a tinted lacquer, prolly white. How do I determine what the original finish was and whether I can just scuff it and shoot? Thanks for your thoughts.
5/3/21       #2: Refinishing ...
Robert Member
Hi Charles, let a professional Finisher complete that project .
5/3/21       #3: Refinishing ...
Thanks for noticing Robert. I'm a cabinet/furniture maker and do all of my own finishing w HVLP. Don't know if that makes me a professional or not. These folks are friends and neighbors, and if I don't take it on they'll probably paint it with a brush. I thought it was a nice piece and deserved better.
5/3/21       #4: Refinishing ...
rich c
If it's really 50 years old, and it's commercially made, it's highly likely it's nitro cellulose lacquer. The time tested method of true verification is with a solvent test in a remote area. Start with a cool solvent and work your way up to a hot one. I believe Robert headed that direction because the solvent test has been used by generations of finishers. I would never just scuff a piece that old. It needs a really good cleaning to make sure to remove any spray polishes used over the decades, as well as smoking residue and hand oils.
5/17/21       #5: Refinishing ...
MHorrillo
Website: http://properwoodfinishing.com
First off, your display cupboard is 1950-1960's. Nitrocellulose was the finish of most manufactures since about 1910. The closer you get to 1910 some of the factories were mixing shellac and nitro. 1960-1980 there were a few using industrial poly's and same materials that were "Hot lacquers" and some early "Acid cats". Conversions varnishes started creeping into the market in the early 1980's. Pure Nitro will soften with lac. thinner, but so will dirt, grime and nicotine so be careful. I would strip before I primed, but cutting it with 280 then prime should not add any bonding issues. Maybe fish eye.
    • Supergrit Abrasives
