plywood door panel finishing
5/4/21
Gary Gossling
We struggle when staining to make plywood door panels match the solid wood stile and rails. how do you all deal with this?
5/4/21       #2: plywood door panel finishing ...
mastercabman
I don't do a lot of stain jobs
But when I do I sand the R&S with 180g.
And the plywood with 220g.
Some wood species you need to do a wash coat for blotching
5/5/21       #3: plywood door panel finishing ...
What problem?
The primary difference is the majority of cabinet ply veneer is rotary cut. The wood grain litterly does not match the face or side grain of the solid wood.
The other problem is the veneer is 1/32 thick then a solid glue layer. Quite different than solid.
We always order plain sliced or qtr sliced plywood when doing stain jobs.
5/5/21       #4: plywood door panel finishing ...
Tom Gafgen
I sand solid woods to 150 and plywood to 180 and they seem to match pretty well .At least thats how I used to do it back before we started painting everything white or gray :}
5/5/21       #5: plywood door panel finishing ...
Robert Member
Toning usually equals out the overall color so it all matches.
5/6/21       #6: plywood door panel finishing ...
Hen Bob Member
I 2nd Adam on getting the plain sliced center panels, defiantly helps.
5/7/21       #7: plywood door panel finishing ...
Gary Gossling
Thanks for the responses. We do use plain sliced. We did have a customer actually request rotary sliced and it stained just fine. Go figure. We have also toned when needed. We will try sanding with a finer grit as suggested.
    • Supergrit Abrasives
