Kremlin Clogging like cottage cheese
5/1/21
MICHAEL ROGOZINSKI Member
I have always used Sherwin-Williams Kem Aqua plus in my Kremlin 15C25 but for the past couple of days the Kem Aqua plus keeps clogging like cottage cheese. I have always cleaned it with acetone after using the Kem Aqua plus but yesterday I pumped out the acetone as I have done numerous times before and started pumping in the Kem Aqua plus sealer and all my filters were clogged like cottage cheese.
Today and without going into a long story I cleaned it out with acetone and then ran 2 quarts of Poly Chem AcraStrip and pump it out and then ran an entirely new batch of Kem Aqua plus sealer and it clogged again like cottage cheese. Does anybody know or what is possibly going on? And of course how I get out of this jam?
5/1/21       #2: Kremlin Clogging like cottage chees ...
Filter the Kem Aqua.
5/1/21       #3: Kremlin Clogging like cottage chees ...
Michael R Member
I did filter. I have an in-line filter and a screen filter and the Kam Aqua plus keeps clogging. This is large clumpy cottage cheese clogging.
5/1/21       #4: Kremlin Clogging like cottage chees ...
First shake the crap out of it to make sure the solids are mixed into the solution. Shake it for 10 minutes which is total overkill. Open the can and stir it up and see what's in there, if there's more chunks shake it more. Then wait for a 1/2 hour for the bubbles to settle out. See what happens.
If not you need filter out the finish before you put it into your pump.
5/1/21       #5: Kremlin Clogging like cottage chees ...
Michael R Member
Thank you Leo, you work so hard for this group. I went back down to the shop and spend about 2 1/2 hours running acetone, citric clean and and about 3 gallons of hot water through the system a quart and time. I did a final test with Ken Aqua plus and absolutely no more clogging. Thanks again for all your hard work and helping me again in another situation. Monday morning back to work like nothing happened!
5/2/21       #6: Kremlin Clogging like cottage chees ...
Dan Cook
We don't use waterbase finish anymore, but we strain all our finish through a fine mesh bag strainer before it goes in the pump plus the inline filters. Also we put something in the bottom of the can that we are pumping from to keep the dip tube off the bottom so it isn't getting any sediment from the bottom of the can. Both of these have helped us to keep the clogging issues down. The Kremlins have an extremely small oriface in the tip and it doesn't take much to clog them.
5/2/21       #7: Kremlin Clogging like cottage chees ...
Use the screened washers for the tip instead of the plain jane white washer. That keeps any crud out of the orifice.
5/4/21       #8: Kremlin Clogging like cottage chees ...
MarkB
Your cottage cheese description screamed of contamination in the pump/lines to me. You dont filter material and have it turn to cottage cheese in the system with WB finishes. If it were cottage cheese/unfiltered going in it would be obvious. I spray nearly 100% waterborne and have never seen the cottage cheese but most definitely have had lumpy issue if I rushed flushing gun/line cleaner or even at times when Ive let the GLC sit and its seemed to loosen up material in the lines and saturate that material but it has stayed in the lines. The fresh material is then contaminated by any of the GLC and glop left behind.
I'd imagine your acetone/acrastrip loosened up good bit of material you didnt know was in the lines and the cottage cheese piled up. The major flush did the trick.
