Wb coatings-AAA or pressure pot and HVLP gun
6/17/21
Tony
I have sprayed solvent based finishes for years, MLC, Mohawk, ChemCraft, SW and started out with just cup guns, then HVLP cup guns, and finally pressure pot set ups and although I'm not an expert by any means, I learned to get the results I wanted and troubleshoot problems. I have recently joined a shop that sprays waterborne. We are using a AAA pump for primer and topcoat. It seems we have issues of one kind or another on every job. This ranges from too much texture/orangepeel, sheen differences, and rough finishes (micro bubbles that appear like solvent pop). Our coatings rep has advised us that this is not the ideal equipmet for WB and has suggested we go to a pressure pot with a conventional gun. I agree (mainly because I am comfortable with that set up from my solvent based days).
I'm just looking for some very basic advise as to what you are using with WB finishes, are these common problems, what brand of equipment you have success with, etc. I am coming in to this ignorant of WB finishes entirely, and I guess looking for a basic primer on these finishes and the proper equipment for them. On a side note, I like the the equipment we are being steered towards as far as a pot and a decent Kremlin or Graco gun, but the cost of a stainless pot has caused us to balk. Any newbie advise would be greatly appreciated. Thank you
6/17/21       #2: Wb coatings-AAA or pressure pot and ...
Just wondering what product you are spraying, secondly where are you spraying and what are the conditions? By that I mean air flow, temperature and humidity, cleanliness of spray area?
Are you mixing properly and checking the viscosity ?
Is your pump maintained?
My opinion without getting more information is that you have bigger problems than your pump.
6/17/21       #4: Wb coatings-AAA or pressure pot and ...
CraigM
I've been using a TriTech T5 airless to spray pigmented WB and have been getting great results. I use 308 or 310 fine finish tips. I too was having trouble when using a AAA or pressure pot, it seems like the trouble starts when you add air into the mix.
6/18/21       #5: Wb coatings-AAA or pressure pot and ...
You just started working with a new shop.
How old is their AAA rig. It's currently being used for wb. What has been sprayed thru it in the past? Who maintained it? Asking if the last guy was a yahoo is a valid question that must be asked with some political correctness.
This would be a different discussion if you just bought a brand new rig and you alone are having problems.
The biggest variable is the rig itself. Not even the product, which is another variable in itself.
6/18/21       #6: Wb coatings-AAA or pressure pot and ...
david zaret Member
tony, what product are you spraying? waterborne isn't that hard - it's a little more sensitive to temperature and humidity, and, as always, you have to dial in the pressure, tip sizes, and air, but it's not that sensitive. unless, of course, you've chosen a product that's particularly difficult. i'm a one-man shop, and i've been spraying sayerlack out of a kremlin (and HVLP) with terrific results. keep things warm, make sure things are clean, and make sure you provide airflow over the drying parts.
    • Supergrit Abrasives
