Arroyo
6/23/21
Jim Kolar
Been using the the ML Campbell Aqui fi universal primer with very good results and then torino for my finish coat. Anybody using the arroyo 1k poly finish? Just looking at making the switch to waterbase as my finish system.
6/28/21       #2: Arroyo ...
Mike Lee Member
Tried Arroyo on a bathroom vanity and door. Both constructed from poplar with MDF panels. Sprayed with a 5 stage Fuji HVLP and 1.8 air cap and needle - no thinning. I think that I could have used a 1.3 if I wanted to. Sprayed the door horizontal and the face frames vertical and sprayed a thin first coat and heavy second. One slight run on the cabinet’s end panel. It was obvious “operator” error. The entrance door for the bathroom had a very slight orange peel, but you had to really get close to notice. Light sanding removed most. My experience with spray finishing is limited but I was extremely happy with the finish. Dried to the touch and flattened out in about 30 minutes, but I waited 24 hours to apply the second coat . I had it tinted to a BM colour (CC30). Clean up was as expected. I will continue to use Arroyo.
    • Supergrit Abrasives
