Best Finish for Restaurant chairs
6/29/21
Jon Thompson Member
Any suggestions for a finish for restaurant chairs ? I usually shoot pre cat lacquer on my customers furniture, but I need something that will take constant use ? I have looked at Mohawk's finishes and thought about the Duracoat. Any help would be appreciated . Thanks.
6/29/21       #2: Best Finish for Restaurant chairs ...
Matt
No matter what you spray, they will take a beating.
Minimally speaking I'd spray them with conversion varnish. That should stand up quite nicely.
You could go with 2K polyurethane if there's money in it for the added cost, however, 2K polyurethane will still take a physical beating similar to the conversion varnish. It's just that it's going to have even more chemical durability, and might get you away with fewer coats.
7/1/21       #3: Best Finish for Restaurant chairs ...
Jon Thompson Member
Thanks, Matt. I just talked to Andrea at Mohawk and I am going with the precatalyzed DuraCoat. Since theses are chairs and not table tops DuraCoat should work. Jon
    • Supergrit Abrasives
