Kremlin and Milesi solvent based
7/16/21
Matthew Atkinson
What is the best way to flush Milesi material out of the system and clean the Kremlin equipment? This product is just killing my equipment. Milesi rep says acetone but it really doesn't do anything as far as I can tell. Every day there are small bits flushing out of the system and causing problems. We didn't have this issue with regular catalyzed varnishes. Lacquer thinner seemed to flush well. Milesi rep says keep standard solvents away from Milesi. I was told that MEK could dissolve Milesi for cleaning tips, etc. Can I use it to flush lines?
7/16/21       #3: Kremlin and Milesi solvent based ...
herb johnson
all your kremlin parts and lines can handle mek with no problem
good luck
herb j
7/16/21       #4: Kremlin and Milesi solvent based ...
Robb Parker  Member
We swapped to MEK for our CAT pumps years ago. Had so many problems flushing lines before that. We flush with MEK then clear lines with lacquer thinner and leave thinner in the lines.
    • Supergrit Abrasives
