Removing paint fumes from spray booth exhaust
8/14/21
Craig Member
I have a shop in my garage.
Is there a way to remove paint smell from the air being exhausted from my spray booth. ? Getting some complaints and rightly so.. lacquer, conversion varnish and especially the polyester has quite the aroma..!
I've tried a 3 filter setup on the extraction fan from course to carbon, it does work, kinda but not great really.
What other options are there, I know I'm probably going to have to move my shop but any ideas would be helpful.
Thank-you
8/14/21       #2: Removing paint fumes from spray boo ...
rich c
Water curtain booth or carbon dry filters for your booth would likely cure your issue. Neither are cheap. But cheaper than taking a business from under the radar, to a legit.
8/15/21       #3: Removing paint fumes from spray boo ...
Spray waterborne. Use a hard hand wax finish like Osmo. What are you spraying polyester on? Good luck trying to get rid of the styrene stench.
8/15/21       #4: Removing paint fumes from spray boo ...
herb johnson
add an extra nine to 12 ft or so of exhaust duct and it will get the exhaust higher into the air it should help quite a bit i would do that before i start adding carbon filters
good luck
herb j
8/15/21       #5: Removing paint fumes from spray boo ...
I would agree with what Herb said, most spray booths vent up high.
The filters are generally used to capture the solids in your spray and don’t really have any affect on odor.
Like mentioned I would consider switching to water based. It has way less odor, is not flammable and the products are just as good as solvent.
You still need to protect your health and wear proper ppe no matter what you are spraying.
8/16/21       #6: Removing paint fumes from spray boo ...
matt
Agreed with the above about spraying waterborne. If you're getting satisfactory results with lacquers, there are waterbornes out there that will do you well.
I sprayed waterborne (SW KemAqua and MLC precat Agualente) for a couple years when I was working on my master's degree, I was a carpenter on staff. They didn't have a proper explosion proof spray booth so waterborne was the only game in town for them, and we made a lot of very nice bookshelves. The facility was right in the middle of a historic district, the exhaust fan went right out the side of the building, and nobody ever noticed or cared.
I'm not sure if either of those finishes are available anymore and I'm sure there are better solutions out there.
8/16/21       #7: Removing paint fumes from spray boo ...
craig Member
Hi. Thanks for the replies!
I might try and put the exhaust up higher but I think I'm kinda hooped either way.. the polyester stinks so bad. I build drums and drum kits and the polyester is the best for me.. I can fill oak, hickory, whatever and get that high build high gloss wet look. I havent been able to do that with any other product. And I've tried a lot..
A water curtain may be an option but thats a big commitment and theres no running water in the shop..
So I think I'm gonna concede and look at an alternative location.. New post incoming about a proper spray booth!
    • Supergrit Abrasives
