Lacquer or Latex
9/5/21
Chris
On painting cabinets are most painting latex or some other finish? I spray mostly Lacquer but do some with S-W Emerald pretty hard finish.
9/6/21       #2: Lacquer or Latex ...
rich c
I thought lacquer lost favor in the 80s for kitchen cabinets?
9/6/21       #3: Lacquer or Latex ...
Chris
Well The S-W store still sells quite a bit of it here where I live I am using the white lacquer tinted to the color they want. What is most common in your area
9/7/21       #4: Lacquer or Latex ...
Mastercabman
Chris
Are you using just lacquer?
Most cabinets shop/manufacturer uses conversion varnish or pre-cat lacquer
Some are using 2K poly or a waterborne finish
I would definitely never use latex on cabinets
The SW emerald is good but that would not be my choice of finish for cabinets
9/8/21       #5: Lacquer or Latex ...
Chris
I’m using Pre cat lacquer
9/8/21       #6: Lacquer or Latex ...
rich c
Most common here is conversion varnish. I used precat on my home kitchen in 1990 and it has not held up well around the dishwasher, and range hood. All conversion varnish after that.
9/10/21       #7: Lacquer or Latex ...
Chris,
Regardless if you use their products ML Campbell has a really good website that shows the differences between all of their products. If you click on “sell sheet” they list the results of the durability testing needed for KCMA approval.
It becomes very obvious which products provide the most protection. The waterbornes do very well.
As others have noted:
80’s were laquer
90’s precat,
2000’s CV & very good waterborne
2010’s CV, 2K poly, very, very good waterborne including 2K
My shop started using 90% wb in the early 2000’s. We used to use a fair amount of Muralo Ultra for interior cabinets. SW Proclassic waterborne was a similar next generation 100% acrylic interior trim paint. They were similar to the Pro waterborne products. Both of the web products were better in most respects than the oil based paints the good builders were using at the time.
Interior cabinets/millwork is not the same as kitchens & baths. Laquers do not like moisture. The original precats in the 90/2000’s also had some trouble around DW sometimes for some people.
ML Campbell
9/10/21       #8: Lacquer or Latex ...
Chris
I have used the Pro Classic but they tell me the Emerald is a better finish then the PC after it cures it is really tough. So you are saying that you spray a lot of the Pro Classic and have good results? I was referring to it as Latex and you are referring to it as Acrylic
9/11/21       #9: Lacquer or Latex ...
Chris,
If you reread my post we used the Muralo from 2000-2005 roughly. The SW Proclassic was a similar product. You could go thru the WW Knowledge Base and read about people using both of those.
Our ML Campbell supplier started tinting their waterborne finishes to match anything including other manufacturers just like a paint store. The Pro grade wb's are significantly better than those off the shelf products as far as spray ability and durability.
I don't know why SW still uses the word "latex". Chemistry wise its an outdated term from the 1990's. The vast majority of wb house paints are acrylic resins.
The waterborne varnishes/laquers are typically acrylic, polyurethane or a mixture of the two. Some of the Pro ones also use polyethylene(ML Campbell), and polycarbonate(Target).
The reality is there is about 5% water in the can. The rest is glycol or other stuff. You shouldn't really add water as a reducer.
    • Supergrit Abrasives
