High pressure diaphram pumps to replace AAA pumps?
11/9/21
Matt
We are purchasing a flatline in the coming months (new) and will be buying new pumps to go with it.
Is anyone using any of the high pressure diaphram pumps such as the Wagner "Cobra" on their flatline, or even with their hand guns?
11/10/21       #2: High pressure diaphram pumps to rep ...
Jim Knowles
Contact Erick Reason
He has a YouTube channel by his name. He has a wagner cobra (40 to one ratio)and is in contact with many finish & equipment suppliers. Mr "test don't guess" He puts products and equipment to the tests......then names names and gives his honest ranking of performance.
I have gleaned many "helpful " tips from his interviews and shared results. He interviews great finishers, gun and pump manufacturers and finish manufacturers and paint chemist. Plus sand paper and pad suppliers.
The thing I like about him is his honesty and humility. He is a builder and a finisher. He sells thoes services only. He does not sell equipment or finishes or sand paper. But he discusses a large variety of thoes products outloud.
I personally don't have time or money to conduct all thoes comparisons. I know he has gone to Italy to meet with the Milesi coatings company people.
All the best
just jim
11/10/21       #3: High pressure diaphram pumps to rep ...
Jim Knowles
Also contact Kevin Backman with all your flat line and pump questions. I am buying an Iwata Icon AAA (36 to 1) from him.
Company: Spray Fish
360 391 8411
just jim
11/10/21       #4: High pressure diaphram pumps to rep ...
herb johnson
hp pressure diaphram pumps are a good way to go if needed, low shear if needed for your product, no pulsation, no packings to replace a very reliabel product just like a diaphragm for any low pressure diaphgram pump used if you use any for stains. also good if you have any abraseive or uv for your automatic line application.
also very low maint pump, just every once and awhile you need to change out internal oil, less than about 6 oz and not very expensive.
good luc
herb k
11/13/21       #5: High pressure diaphram pumps to rep ...
Jim Knowles
I have made a mistake in my first post in this thread! Eric went to Renner in Italy. Not Milesi....
Sorry!
    • Supergrit Abrasives
