Gravity Feed Gun
11/27/21
Tom Gafgen
Can anyone recommend a decent quality Hybrid gravity feed gun comparable to the Binks Trophy ? Only needed to spray CV clears and pigmented on the occasional job too small for the Kremlin but must be able to do a quality job .
The Binks cost $575 so I'm looking for something a little less expensive .
Thx
11/27/21       #2: Gravity Feed Gun ...
nicko
I have a C.A. Technologies hvlp cpr reduced pressure gravity gun it has an hvlp and cpr cap. The cpr cap is for spraying higher volume. It has been a great gun for CV. You can pick up the woodworking kit for about $450.00.
nicko
11/27/21       #3: Gravity Feed Gun ...
Mastercabman
I'm also a big fan of CAT
I have a J100 gravity (Jaguar)
It is very good,also low CFM 6-8 depending on air cap
The CPR that Nick suggested is really good
A little more air hungry
And don't forget to look at the X guns
Also very good
I was told that the X's spray fan is wet edge to edge!
11/27/21       #4: Gravity Feed Gun ...
duster
We use a 3M PPS gravity gun for small projects like single pieces of furniture. It works well for us when we don't want to use our Graco Falcon AAA set up. They only cost about $225 to start, and use disposable tips, cup liners, and caps. We used it to spray CV on this dining table a couple of weeks ago.
View higher quality, full size image (800 X 621)
11/30/21       #5: Gravity Feed Gun ...
chris
check out a binks SV100. less than $300 but sprays well.
also use on smaller jobs with 3M cup.
