infrared lamps
1/2/22
dave anderson
does anyone use portable infrared heat lamps to speed up dry and cure time , we use CV most of the time, any thoughts?
1/2/22       #2: infrared lamps ...
CraigM
I've had a Sunspot system with 2 heads (GreenFastCure in the states) for about 8 months. It's been a game changer in terms of speeding things up. I spray 2k poly, CV, solvent and WB. Where it really shines is WB. Took a bit of experimenting to find optimum times/ gas percentages for each coating but I've got it pretty dialed now.
1/3/22       #3: infrared lamps ...
dave anderson
how much are those sunspots? hard too find prices or a distributor that knows anything. I was look at those plug in infrared lights
1/3/22       #4: infrared lamps ...
SteveL Member
I use a plug in Lamp just a smaller 110v unit, I think I got it off amazon just to give it a try. Works great, definitely speeds up things.
1/3/22       #5: infrared lamps ...
CraigM
Dave, I sent you a message via woodweb, might be in your email spam
1/5/22       #6: infrared lamps ...
Is there any issue with curing the skin more than the entire film thickness?
1/5/22       #7: infrared lamps ...
CraigM
RichC, the IR setup I have cures from the inside out, so top of the film cures last. I measure the parts with an IR thermometer, once they hit about 45C I pull them out.
1/8/22       #8: infrared lamps ...
Jonathan Mahnken
I have two infratech brand mobile IR lights. the cure from the inside out thing is kinda true. if you over do it you will still wrinkle the skin of the coating. Good for curing things like tops, small furniture and samples. to be effective with larger pieces/amounts of work then you need a pretty big unit, or tunnel. For my waterbased operation I ended up choosing heated forced air. It warms the whole piece, not just the part exposed to the light.
