Re-coating Pre Cat Lacquer Finish Cabinet Doors
1/8/22
howard
Website: http://woodcontours.net
I have several cabinet doors that were sprayed with a color match SW pre cat lacquer that need refinishing. I know that during initial finishing each coat of pre cat needs to go on within an hour of each other. Can pre cat be recoated when the finish is more than one year old? I wasn't sure if there would be an adhesion issue, given that the new coat would burn in, but the chemistry of having the layers bond would be different. If need be I will sand it down and start over, but would love to avoid this. All suggestions welcome. Thanks
1/9/22       #2: Re-coating Pre Cat Lacquer Finish C ...
You've got two options with most coatings. Hot coats that chemically bond to each other. The reaction or evaporation hasn't completed so the next coat burns into the previous one. The other option is mechanically bond. Just like glue. The problem is that the finishes we use are plastics. New coats don't like to stick to smooth surfaces. You need to abrade/sand the glossy sheen off. In the case of an old finish 240 grit would be the go. Between coats 320 grit is typical. The vast majority of coats of finish put on in the world regardless if it's precat laqeur or not are sanded.
1/9/22       #3: Re-coating Pre Cat Lacquer Finish C ...
Al
Adam,
Should you clean doors before sanding? If so what is a good cleanser? I have similar situation as Howard coming up.
1/9/22       #4: Re-coating Pre Cat Lacquer Finish C ...
Mastercabman
Yes,
scuff sand and clean them up
I use Naphtha to clean
1/9/22       #5: Re-coating Pre Cat Lacquer Finish C ...
Bob Niemeyer  Member
Also watch your total DFT. SW precat does not like high DFT's. Cant tell you how many checked SW finishes I see out there.
1/9/22       #6: Re-coating Pre Cat Lacquer Finish C ...
Scuff it and spray. Since the finish is fully cured it's unlikely you need to worry about the mil thickness.
1/11/22       #7: Re-coating Pre Cat Lacquer Finish C ...
Gary
Make sure they are cleaned good. any type of furniture polish or grease you do not get off, will give you major headaches
1/11/22       #8: Re-coating Pre Cat Lacquer Finish C ...
howard
Thanks everyone for the help and how to proceed
    • Supergrit Abrasives
