Sherwood waterborne over MDF
1/14/22
MB
I'm using Sherwood "Waterborne White Topcoat" M64 F 1541 on doors with MDF center panels. The data sheet says it's self sealing and has no sealer/primer/surfacer recommendation. I feel like some type of sealer would be helpful.
It's actually a clear base tinted to a dark color, so I'm thinking something clear would be nice. Would shellac work?
Anyone have experience with this? The local SW support is a little weak. They seem more in tune with painting walls.
Sherwood_Topcoat.pdf
1/14/22       #2: Sherwood waterborne over MDF ...
Mark B
Why not just run a couple tests as the material is specified and with your adjustments. From a liability standpoint I dont know why you'd try to supersede the manufacturers spec. Once youve crossed that line anything and everything is on you.
I'd personally just stay with Sherwin's schedule and be done with it.
1/14/22       #3: Sherwood waterborne over MDF ...
The adhesiveness of waterborne finishes in general don't require primer. The primer is used to improve the surface. Show defects, raise grain, etc.
As Mark suggested do a test panel. We primarily use MLC Aqualente. I wouldn't use it without the primer, because its a pigmented finish. Basically a clear with pigment. You need the primer to perfect the surface.
2/2/22       #4: Sherwood waterborne over MDF ...
Nick Sinderson
Re; waterborne primers
Chemcraft Aquaprime!, get some and you will wonder why you haven't been using this stuff from the get go!
