Paint cracks in Baltic birch
3/9/22
Mike Member
We are using 3/8 Baltic birch plywood for flat panel painted doors. We built these cabinets and stored them waiting for the job to be ready to accept them. The day came when we were delivering cabinets and we found that on a lot of the Baltic Birch panels the paint had cracked but the Stiles and rails were fine. The cracks all ran with the grain, we can't figure out why the Baltic Birch panels cracked but the stiles and rails, the hardwood was fine. I'm looking for any information from someone who could lend some insight as to why the plywood would do this but not the hardwood. Our primer and paint are both post catalyzed products and we've been using Baltic birch for panels for about two years with no incidents.
3/9/22       #2: Paint cracks in Baltic birch ...
Tyler Member
My best guess would be a poor veneer job on your 3/8 panels. We've had product come in before where the veneer had little fissures in it that you couldn't see until painted. We tried to fill the fissures and repaint the panels, but the cracks came back in a few days, we had to scrap the material and start over.
3/9/22       #3: Paint cracks in Baltic birch ...
duster
Mdf would be a far superior material to use for the flat panel in your painted doors. Smoother, flatter, more stable, and less expensive. Don't let the anti mdf snobs tell you otherwise.
3/9/22       #4: Paint cracks in Baltic birch ...
Sounds like damp plywood that you bought and it dried out and shrank enough to crack the paint.
3/11/22       #5: Paint cracks in Baltic birch ...
I agree 100% with duster.
Glueing the panels increases the strength of the door, stops rattling, panel/slot cracking.
We've been using 3/8" mdf for 20 years. Likewise 5/8" double refined mdf raised panels.
3/11/22       #6: Paint cracks in Baltic birch ...
Dave Edgerton  Member
That is typical of Baltic birch, it should never be used for paint finish. If your finish is waterbased, the glue in Baltic birch is not water resistant either
3/12/22       #7: Paint cracks in Baltic birch ...
masterblaster
cracking with the grain is a wood product failure...usually moisture level is out of spec. cracking in all directions is a coating failure....usually to thick or to britle so it could be an application issue or the coating itself.
    • Supergrit Abrasives
