Post Cat Lacquer vs. Conversion Varnish
3/14/22
howard Member
Website: http://woodcontours.net
I have experience spraying post cat lacquer, but have not used conversion varnish. Are there differences between the two that I need to look out for besides needing to get each coat down in a set amount of time? Also, any reason to use a vinyl sealer, I have done this in the past, but I am wondering if it's just easier to seal with a thinned down topcoat. This will be for a kitchen table. Thanks for the help.
3/16/22       #2: Post Cat Lacquer vs. Conversion Var ...
Kevin Dunphy
Website: http://www.kdunphy.com/
Your work looks really good, for sure get away from the laquer 2k is the same price as conversion varnish also water base is coming on strong.
I assume you don't have a pump makes a big difference. Seem you need to take a hard look at your finishes
I'm going to shameless promote a video I did on 2 k hard to type the points
https://www.youtube.com/watch?v=prGNLwxOGs4&t=226s
3/22/22       #3: Post Cat Lacquer vs. Conversion Var ...
Riggse
Cv is far better than a lacquer in every way..feel look and performace.
but a lacquer builds better, and cvs dont.
not sure what your needs are, but precats are a budget finish. simply put
    • Supergrit Abrasives
