Spraying Conversion Varnish
3/19/22
howard Member
Website: http://woodcontours.net
1) What needle should I use, I'm using a Mohawk product?
2) Spray pattern - is it the same when spraying lacquer, going first in one direction and then going at 90 degrees? Do I need to be careful with overlap?
3) How sensitive is it to temperature and humidity? I'll be able to keep the temp at around 70 degrees, humidity I can't control.
Thanks as always.
3/19/22       #2: Spraying Conversion Varnish ...
What are you spraying with?
3/20/22       #3: Spraying Conversion Varnish ...
Kevin Dunphy
Website: http://www.kdunphy.com/
Your 2nd question is hard to answer it screams I don't know the basics.
Get experience the best is to get a kitchen door spraying job, having a good hand is number one skill to learn.
Mohawk has lots of videos learn and watch the hand also Youtube but find experienced guys not want a be.
I've almost finished a high gloss video showing burled elm from a 1991 MG .
Also, there is no stupid question just spend a little time first
3rd question high heat is an enemy when spraying can bubble on certain lacquers had it happen on conversion varnish
3/20/22       #4: Spraying Conversion Varnish ...
Don't know about Mohawk. But ML Campbell always states 25ºC (77ºF) which of course is very warm but heat will generally not cause solvent pop. Air currents over the wet substrate are usually the culprit for solvent pop bubbles.
3/20/22       #5: Spraying Conversion Varnish ...
Mastercabman
So for your first question,we need to know more
What exactly are you using and what kind of spray equipment you're using
For the second question
Start at the edge (center of fan)
Then go back with a 50% overlap and so on
For your third question
Ideally most finish is based on 77`/ 50% humidity
Don't spray under 65`
If it gets too warm,start to use flow enhancer to slow down the drying
3/23/22       #6: Spraying Conversion Varnish ...
Kevin Dunphy
Here is the video of high gloss clear it's good to understand the process and can change the look of a furniture guy.
What I see a lot in videos is guys flicking their wrist not keeping the arm straight and understanding why that is a huge difference .
I had someone come in the shop wanting a job as a finisher that never sprayed vertical but wanted to learn at my shop at 22dollars an hr. only because where he's working there dumbing down the work making everything flat.
I was lucky enough to work a few years in aircraft executive jets doing high gloss finishes that were polished.I had a car finisher that worked there helped me a lot to learn proper spray techniques were not born with the gun in our hand.
Also, that experience taught me to be so careful with my health these chemicals are no joke
https://www.youtube.com/watch?v=OrKlWt06aZE&t=15s
3/23/22       #7: Spraying Conversion Varnish ...
Christopher Tayler Member
Use a 1.4-1.6 tip and I start thinning the CV at 10%. On humid days I add C1161 retarder. Start it at 1-2% and no more than 5%.
3/25/22       #8: Spraying Conversion Varnish ...
JeffA
So Kevin Dunphy, did you hire the kid?
3/26/22       #9: Spraying Conversion Varnish ...
Kevin Dunphy
No there was another flag he told me he didn't like the wear and tear on his vehicle I was only 10 mins away from home and where he worked was an hr. away. Plus my shop isn't geared for a full-time finisher.
I need someone that can install, prepare wood, assemble cabinets and learn the CNC. Still waiting for someone that can fit, hard because the shops in the area think it's it better to keep the workers one dimensional [example head installer, head sander, head assembler ] I think it's so boring for the workers. I don't think you can be a cabinetmaker unless you can spray, install and design.
I know the only way is to have someone that is young, green and to train.
But were in a time of great exchange of ideas thanks to the computer I learned how to run the CNC on Shopbot form 13 years ago the sign guys opened my eyes.
3/27/22       #10: Spraying Conversion Varnish ...
JeffA
The larger kitchen cabinet factories here in MN are paying at least $20.00 an hour to start and $22.00 and more if 2nd or 3rd shift. When I see a person that all they do is blow off sawdust on parts before finishing and are paid that amount I'm just flabbergasted. You can still find 1 bedroom rentals for around $500 per month that also include heat here. It's just crazy.....
3/27/22       #11: Spraying Conversion Varnish ...
Kevin Dunphy
That larger kitchen cabinet factories also has a couple of designer who talk about craftmanship.
I was hoping with CNC being affordable there would be more guys doing real custom work so you don't have an old man yelling at the sky.
I have a new video out on cabinet material basic construction hoping someone like Dave does a video
The sad thing is when someone walks out of those big factories in 10 years they have zero skills the only place they end up is at the big box stores selling kitchens.
3/30/22       #12: Spraying Conversion Varnish ...
tiptop
I'm not sure we're comparing apples to apples here. Mr Dunphy is located in Canada so I'm thinking rates of pay may not be equal. That said, you will definitely not find an experienced finisher in the mid-Atlantic states for $20-22 hr. Of course, you're not going to find any apts. at $500 month either.
I'm in agreement with Chris Tayler in his points; also taking into account that he's speaking from experience. Have a great weekend!
4/1/22       #13: Spraying Conversion Varnish ...
Kevin Dunphy
That wasn't the point the 22 an hr. The skill level is dropping in cabinet making. My son makes almost 6 figures I can't afford him he won't be running the shop and his girlfriend is looking at 6 figures teaching at the university. I'm well aware of the wages in today's world
You look on Youtube is full of people who never spent one minute in a cabinet shop giving out cabinet-making advice. The experienced shop is going the way of the dinosaurs for lots of reasons mainly so expensive to open a shop even a decent 4 man. I grew up in Toronto so I've seen crushing rents firsthand.
So there is a big hole for mini-factory shops all advice is given by salesman selling equipment. Hence all you need is min wage workers so the cycle of skilled workers is accelerated.
Sorry if I hijack this thread just wanted to make a point
Also, I have a new video on the subject
https://youtu.be/_OoGaDuMWJU
    • Supergrit Abrasives
