Ultrasonic cleaner solution.
5/20/22
Jeff
I purchased an ultrasonic cleaner recently for cleaning my spray gun parts, I am wondering what product , solution, home brew you are using in your ultrasonic cleaners. I am using all water base products, Envirolak, Renner, ICA and Sayerlack.
I read that some were using acrastrip with good results, I live in Western Canada and can't find a supplier anywhere close.
5/20/22       #2: Ultrasonic cleaner solution. ...
I use MLC GLC10 30% into water.
5/21/22       #3: Ultrasonic cleaner solution. ...
CraigM
Columbia Industrial Supplies in Victoria might have Acrastrip, they have in the past.I'm in BC, I have a pail of Acrastrip 800 that I got from Composites Canada in Mississauga. Heated acrastrip in an ultrasonic cleans guns better than anything I've used before it. It doesn't seem to affect seals either. I think Envirolak makes a cleaner that's similar.
5/21/22       #4: Ultrasonic cleaner solution. ...
Jim Clark
I put my air cap and nozzle in a small glass filled with lacquer thinner,
then sit the glass in the ultrasonic cleaner that's filled with water.
does a great job.
5/21/22       #5: Ultrasonic cleaner solution. ...
I've done that with a 100% GLC10 instead of mixing up a gallon of the water/GLC mixture.
When I have to clean the whole gun I use the gallon mixture.
5/21/22       #6: Ultrasonic cleaner solution. ...
Jeff
Thanks for the information, I tried the Envirolak product, but I didn’t think it worked that great, maybe I was expecting more.
Jim,
Does the container you put in the ultrasonic cleaner have a lid on it?
5/21/22       #7: Ultrasonic cleaner solution. ...
Getting layered on paint off a gun takes a long time and you need to scrub. At least that's my experience. Smaller parts that don't get caked don't take nearly as long. Getting the orifices cleaned is really the goal. Having the gun look pretty again is nice too.
I've done stupid things like leave finish in the gun and the tip gets locked up with dried finish. Put it in the Ultrasonic cleaner for about an hour with a stripper solution and 140ºF heat and the clog come out. So it really does work well.
5/21/22       #8: Ultrasonic cleaner solution. ...
Jeff
Jim,
5/22/22       #9: Ultrasonic cleaner solution. ...
Jim Clark
No lid on my container, the glass is just a small bar type drinking glass
about 6 oz. My ultrasonic cleaner is a small one like sold at
Harbor Freight, not big enough for a complete gun,
it has a lid but can't be closed with the glass sitting in it.
It is amazing the residue it removes from what looks like a
completely clean item like a air cap or nozzle.
7/9/22       #10: Ultrasonic cleaner solution. ...
Denny J
We have been using Enviroclean in ours for the last year.
For regular maintenance it works quickly. For multi layered items it can take multiple cycles to get everything off
    • Supergrit Abrasives
