Graco Merkur pump
5/27/22
Mastercabman
Just an update on a post that I started a while back
I purchased a Graco pump back in November
I used it a few times and it never really worked the way I thought it should
So took it back to the place I got it back in January 20th
Technician looked at it and pressure tested it
He found that the fluid pressure was not right according to air pressure input
So they ordered a new part to see if that was it
Took several weeks (well about 3 months)
So they replaced the part,did a hydro test and it looked good
But he told me that he wanted to redo a test with something else other than water(thicker product)
Weeks goes by and finally got a call from him yesterday
"Test did not go well
Graco is replacing the whole unit under warranty"
So the good news is ,I was not crazy when I suspected the unit wasn't working properly
But it took a lonnnng time to get it sorted out
About 4 1/2 months later!
I'm expecting to pick up the replacement next week Friday!
I will put it to test and keep you posted
5/27/22       #2: Graco Merkur pump ...
Sorry for your bad luck, nothing like being that person that gets a lemon. I know a guy who used those pumps, he loved them and they are really good pumps. I thought about buying one from him when he retired, but I already have more pumps than I need.
6/9/22       #3: Graco Merkur pump ...
Mastercabman
So finally got to pick up the replacement unit today(1week later)
I'll be setting up the pump this weekend and try it out
Will post later!!
6/11/22       #4: Graco Merkur pump ...
Mastercabman
Update
I did some spraying today with the Graco Merkur
Sprayed some white vinyl primer and it seems to work just fine
So let's hope this is it!
    • Supergrit Abrasives
